hope someone can help I ccant get rid of the
lining light and brake warning light - always on
I did some tests
The sensors :
removed the connection and tested across sensor
with continuety meter. sensor shows short. this is normal i think .
(worn pads = open circuit)
The switch on master cylinder - float switch.
Disconnecting both wires from float switch and measuring across the WIRES.
shows short or closed circuit??? This doesnt seem normal and there
is no indication of cut, damaged wiiring.
I
Any ideas?
