Results 1 to 7 of 7
Thread: DOOR OPEN madness, valve cover gaskets...
    Apr 2004
    New Hampshire
    Default DOOR OPEN madness, valve cover gaskets...
    Hello all. I have a couple questions;
    First, once in a while I get the DOOR OPEN message for seemingly no reason. (The doors are closed, once I even went around the car beforehand, opening and closing each one ) This morning it got worse, during my half hour commute it just kept on ding'ing evey couple minutes or so... Has anyone else had this problem? I've searched around for info here and elsewhere and haven't found much...
    Second, my '95 540i has some leaky valve cover gaskets and this weekend I was planning on changing them (and prolly the spark plugs too). I've read everything I can find regarding this project (stuff on this board, the bentley manual, etc.) and I was wondering, do any of you guys have a particular gasket sealant preference? I've seen some recommend Permatex (sp?) and I think the bentley manual recommends hylomar (IIRC). Does it really make much difference? Also, this will be my first "serious" project on my e34 but from what I've read it seems like a relatively easy job. Is it really as straightforward as it sounds? What should I watch out for?
    Any info is apreciated!
    Dennis
    '95 540i 6sp, uuc ssk, Dinan chip
    proud member of the nikasil club
    Default (bong) Door Open. (bong) Door Open. (bong) Door Open.
    Sound familiar?
    My first e34 did that all the time. The door sensor is part of the striker plate on the car, if you look closely you'll see a little nub that gets depressed when the door is closed.
    That is, if the door catch is properly aligned and the parts aren't worn out!
    The professional fix in my case would have been to buy a new drivers door striker plate assembly, as that was the one that was worn out and causing the system to think the door was open.
    The real fix was to swap the driver door striker plate with the rear passenger side plate, the least worn one on the car. That fixed my Door Open chime for good.
    HTH
    Robin
    72 Chevy K10
    01 E39 M5
    Default I had the same problem on one of my 1991 525i's
    3 years ago. I simply wrapped some duct tape around the door catch where the sensor is to build up the area so there was more pressure when the door was shut. Haven't had any more problems for over 3 ytears.
    Dick Schneiders
    Quote Originally Posted by Robin-535im
    Sound familiar?
    HTH
    Apr 2004
    New Hampshire
    Quote Originally Posted by Dick Schneiders
    I tried duct tape a while back but I abandoned the idea when I realized how difficult it was to actually hold down the button with the tape.. I can't believe I didnt think to just leave it there to eliminate the gap when the door is closed, thanks Dick! The strategically placed tape works well to end the noise
    Dennis M.
    San Jose, Ca.
    On the valve cover gaskets, I didn't use any sealer. I can't remember (did this 2 years ago) if there was any recommendation to not use a sealant or not.
    The only problem you will run into is the clearance on the passenger side when removing the valve cover. The A/C lines were interfering with the cover removal so I released a clamp and was able to move the A/C lines out of the way just enought to clear. Also I believe the Bentley states to remove the harness for the coilpacks. I just folded the connectors back out of the way and taped them there.
    Here's a picture.
    http://www.webshots.com/search?new=1...BMW+540iA+Head
    1995 540iA - 1988 535i 5 Speed
    1980 528i 5 Speed - 1980 528iA (Sold)
    San Jose, Ca.
    If you press "View Slideshow" on the pic link there are a few other pics of the covers..
    http://community.webshots.com/photo/...65623840soNfVI
    Apr 2004
    New Hampshire
    Thanks!
  1. M60 valve cover gaskets this weekend
    Last Post: 03-24-2007, 06:22 AM
  2. replacing valve cover gaskets
    Last Post: 02-04-2007, 12:42 PM
  3. Valve Cover Gaskets
    By hinchcliffe in forum 5 Series BMW
    Last Post: 01-01-2007, 04:19 PM
  4. Valve cover gaskets - replace or not?
    By pingu in forum 5 Series BMW
    Last Post: 05-27-2006, 10:24 PM
