Thread: Power window problem
    Default Power window problem
    Hi, my drivers side power window on my 1995 525it will roll down but not up. the window will stop in different positions every time that I try to put it back up. When it stops I can still here the motor running and it makes like a click click sound. One day it rained and I put the window down and it went right back up. I took the door apart to look at the gears but the dam thing is riveted to the door. What do you think is causing this?
    Kenneth Hopel
    Greensboro, NC
    Jul 2004
    Quote Originally Posted by Riddler
    Kenneth Hopel
    Greensboro, NC
    Hi, i think you have to get the motor replaced but hopefully im jumping to conclusions , good luck with it
    steve mackney
    1993 540ia sydney australia
    Dayton, Ohio
    Do you windows roll up with holding the key in the lock position on the drivers side door?? This could help eliminate a window switch issue, and help narrow it down to a motor.
    Former: 95-530iM
    Current: 99 GMC Seirra 1500
    Default Its a broken tooth on the gear as
    shown here. Its not a switch problem. The reason it worked when it rained was the rained lubricated the window just enough for the gear to be able to continue past the broken tooth. When its dry there's more resistance to the window sliding and it halts long enough at the bad tooth to make that ratcheting sound. You'll have to replace the window regulator, BMA has the OEM ones for around 100.
    Kenneth Hopel
    Greensboro, NC
    Minneapolis, MN. USA
    Default Hey Bill...
    As always, you're totally AWESOME! Thanks for the PICS!
    -Eric
    (OO ( )( ) OO)
    1995 BMW 540i
    Minneapolis Bimmer Group Founder
    Default Well what part is the regulator?
    You are showing pictures of the power window motor correct? Are you calling this the regulator?
  1. Weird Power Window problem
    By stargazer_61 in forum 5 Series BMW
    Last Post: 03-13-2007, 09:06 AM
  2. Power Window Problem 1995 525i
    By CBC in forum 5 Series BMW
    Last Post: 06-03-2006, 08:11 AM
  3. Power Window Problem- Diagnosis?
    By maestronomer in forum 5 Series BMW
    Last Post: 04-25-2005, 10:20 PM
  4. Replies: 2
    Last Post: 12-01-2004, 02:58 PM
  5. Power Window Help Me PLEASE !
    By riot in forum 5 Series BMW
    Last Post: 07-05-2004, 02:13 PM
