Results 1 to 10 of 19
Thread: The Quest of Microfilter
    Default The Quest of Microfilter
    Hi guys, after a couple ours of fiddling around i've come to a dead end. Cars in the garage with a few pieces all over the place. I've tried following instructions for microfilter replacement but my housing is all 2 peice.
    But mine looks like the following with no grey bit at the end. There is no old filter in it atm! its all empty! As you can see in the dodgy pictures mine has no entrance. How am i surpose to fit it all in there? The black side covering is impossible to get, theres one screw left and its above where hands dont reach? Going by the bentley and some other instructions from bmwe34.net.
    Please someone advise me on what to do?
    It looks likes mine wasnt ment to be, so how do i get rid of that stale smell from the air con.
    First, what year is your car? US? Euro? Not all of the cars had them.
    On the bottom there is a gray clip with the brass piece over it. Squeeze it (top and bottom) and it will slide out. Makes access to that screw easier. The top of my "door" has a plastic handle that you turn to remove the door.
    I can't make out too many details in that picture, but what is that black area on the plastic cover?
    For the stale air there are products that you can purchase to clean what might be growing in your AC system. Once a month I start my car up, open the hood, turn on the HEAT on high then turn the fan on high. Where the cabin air intake is under the cowl I spray some Lysol (on both sides) and let it run for a bit. It seems to keep it smelling unmusty and fresh.
    Im australian so i guess euro. This is just pure stupidity, why have a housing but no door, there is plenty of room in there for a filter. i felt in there and could feel the evaporator etc. All i have removed is the sword the card controller u see there in the pic. So am i basically surpose to drive round with my windows down when it gets too staleish in the car from the a/c? I knew not all the cars had them, but couldnt find anywhere which ones did and which ones didnt?
    Thanks for posting rickm, i appreciate all the help i can get on this.
    thanks (posted at same time)
    After 15 minutes the larger image you posted still hasn't DLed, is that a TIFF?
    The housing would have to be there to hold the finned thing that's in there. If that wasn't there...and the finned item decided to leak...then you'd have a mess. (I know, "finned item"....I've been up since 5am yesterday.)
    hehe. Yer im not sure about the pic, its the same as the others *shrugs*. I think i'll call it a nite and i'll take up ur idea of the Lysol and flushing it out Thanks for you time rick, get some sleep haha.
    Atlanta
    Hate to say this, but I don't think a filter will do you any good. These filters are just some fibers with maybe charcoal. Hardly anything that would take care of musty stale air. Good for keeping pollen and dust out though. I'd take a look at killing whatever is causing the odors to begin with. Good luck--sounds like it could be a big job.
    Julius, is there any connection between the smell and your missing pet hampster?
    Hope you got my other message suggesting how to fix it.
    Good luck,
    Geoff
    '94 525iA
  1. Microfilter
    By bertiecbx550 in forum 5 Series BMW
    Last Post: 05-03-2009, 01:47 AM
  2. Microfilter for LHD/RHD
    Last Post: 02-26-2007, 05:48 PM
  3. My quest for axles
    Last Post: 08-26-2006, 11:58 PM
  4. microfilter
    By slupregime in forum 5 Series BMW
    Last Post: 08-03-2006, 09:35 PM
  5. Microfilter rant
    By Karl in forum 5 Series BMW
    Last Post: 03-14-2006, 09:10 AM
