My driver side power window just went out. The window will roll down but not up. Does anyone know of this problem?![]()
My driver side rear window started acting up with the same symptoms. I cleaned up the window switch and it's back working fine. Good luck.
Curt.
1994 530iT
Well the moter is working when I try to put the window back up but the window does not move. I can hear the moter working.
sounds like maybe the window is off track or the plastic track sliders took a dump and got jammed on you. Take it apart and diagnose the problem.
