Results 1 to 10 of 13
Thread: When should the aux fan kick-in?
    Jul 2004
    Default When should the aux fan kick-in?
    Hello,
    I have just fixed the ballast resistor problem on my aux fan, and it is working fine when I turn A/C on.
    But anyone knows at what temperature it should start blowing without A/C turned on?
    My temperature gauge arrow was halfway between 1/2 and 3/4 marks, but the aux. fan was not blowing. Is this normal, or should I replace the aux. fan switch in radiator?
    And is it normal, that in heavy traffic and hot weather the temperature gauge arrow stays halfway between 1/2 and 3/4 marks?
    BTW, my car is 525, E34 M20 1988
    thank you,
    g.v.
    Minnesota
    On my 535i the aux fan was coming on "low" either with AC switched on or when temp guage was between 1/2 and 3/4, it came on "high" at or above 3/4. This was happening in traffic when my fan clutch was shot. When the car is hot and you have the hood up you should feel alot of air blowing from the engine fan if the fan clutch is good. If good, and you shut the hot car off the engine fan should come to an abrupt stop. Mine was "freewheeling" and not blowing alot of air. Replaced the fan clutch and no overheating problem thereafter. Check that fan clutch operation.
    Toronto
    Default It should come on when you turn the AC on
    If not, the something is not working properly. Also your temp guage should always be at 12 o'clock. Regardless.
    Quote Originally Posted by gvilkelis
    Hello,
    thank you,
    g.v.
    turn the key on and play with the wires on the switch on the side of the radiator with a jumper wire to check it's operation, the engine can be overheating it's ass off and not turn on the fan if the hot water is not getting to the switch from a stuck thermostat
    A little clarification, as I'm trying to troubleshoot my aux fan also.
    On the passenger side of the radiator, there is a sensor of some kind that plugs into the radiator, it has 3 wires. This is what you're talking about, right? I don't remember the colors, pretty sure one was brown. I tried jumpering all different ones, but got nothing. I didn't have my voltmeter or bentley with me so I didn't worry about it and just set it aside.
    So in short, what do each of the three wires do, and which ones should you jumper? Does one of them need to be shorted to ground?
    Jul 2004
    Yes, it does start blowing when A/C is on.
    About the cooling system - I previous owner has replaced radiator ar water pump, I have replaced fan clucth and the termostat.
    What else could be wrong with the cooling system?
    One strange thing I have notice - if I press accelerator pedal to 5000 rpm, then for about 1 second or less one hose squeezes, then it comes back to its normal shape. Does this indicates, that there is a circulation problem somewhere or is it normal?
    How could I detect a circulation problem?
    Jul 2004
    Jul 2004
    My fan clutch has been replaced about half a year ago, I have also replaced the termostat, radiator and water pump were also replaced earlier.
    I am running out of ideas what could be wrong with cooling system
    Toronto
    Default I meant the Aux fan should come on when the AC is on
    If not, I think that you may have a seized fan from what I have read in the previous postings.
    perfect, thanks
  1. Some kick ass updates
    Last Post: 02-17-2008, 04:21 AM
  2. Flamin'Cow... Ain't got to lie to kick it....
    By Phatty5BMW in forum 5 Series BMW
    Last Post: 02-01-2007, 01:17 AM
  3. OT: Can u kick it? ------> Ouch!!
    By RockJock in forum 5 Series BMW
    Last Post: 07-06-2006, 01:30 AM
  4. A kick in the nuts with the E36
    Last Post: 07-09-2005, 02:08 PM
  5. OT: Kick ass Porsche vid!
    By TheGeak in forum 5 Series BMW
    Last Post: 04-14-2004, 06:35 PM
