Results 1 to 9 of 9
Thread: V-8 Intake Gasket Replace now Clutch doesn't work?????
    Houston TX
    Default V-8 Intake Gasket Replace now Clutch doesn't work?????
    Replaced water pump then had oring's where tubes go to back of block start leaking...so removed intake replaced gaskets PCV plate etc etc and started her up.....took for hard test drive (Wife would take to work in morning) and she ran great..better than ever. In the morning....5 hours later!! Clutch wouldn't engage.....like clutch slave or master is bad.....can't see how changing intake gaskets had anything to do with it....coincidence???? Any thoughts..
    Thanks
    Callen 91 535i 94 530i 89 75il
    it's a coincidence i don't know what to say other then looking for wet spots by the peddles and or fluid dripping from the bottom of the tranny
    Wait, if it wont engage then its not fluid its mechanical, the fluid just dis engages right? or am i missing something?
    Houston TX
    None....bone dry, resevoir was full.......
    Replaced the slave cylinder last night just in case and bled her good and still same thing......can get in gear when off but can't when started. Can hear the pressure plate when clutch is ingaged.....
    Hate to try clutch master and stil not fix it...next step pull transmission....ARGHHHH
    Houston TX
    when you push clutch in it disengages engine from transmission....my problem is classic hydraulic but afraid I may have clutch disc, pressure or throw out bearing problem.....
    Default Or antifreeze on the clutch
    amen for auto trans cars!
    Boston, Ma
    ha, thats the first time i've heard that one
    Default mine wont slip even if I throw oil at it!
    :d
    Houston TX
    Sooo Funny......
  1. How to replace oil pan gasket? plz help!!!
    By oleh in forum 5 Series BMW
    Last Post: 07-19-2017, 05:29 AM
  2. idling problems ...intake gasket??
    By DaveVoorhis in forum 5 Series BMW
    Last Post: 04-27-2008, 07:43 PM
  3. Trans program after Intake Gasket R&R
    By Evan in forum 5 Series BMW
    Last Post: 05-13-2007, 04:47 PM
  4. Intake gasket question.
    Last Post: 12-25-2006, 01:38 PM
  5. M60 Intake gasket placement
    By Alpinewhite in forum 5 Series BMW
    Last Post: 11-19-2006, 08:59 PM
