Results 1 to 4 of 4
Thread: '90 525i - radiator leaking around bleed screw - new screw so O-ring is good
    Jul 2004
    Default '90 525i - radiator leaking around bleed screw - new screw so O-ring is good
    1990 525i, 236k miles
    Two years ago the bleed screw broke off and the dealer had to "drill" it out and put a new one in. It ran fine until about 2 months ago.
    After lots of observations, I see it's leaking around the bleed screw. I thought it might be the o-ring so I replaced the bleed screw - it still does the same thing - little spits of water come from around the bleed screw when it's at operating temp.
    Any ideas? Thanks!
    baton rouge, loserana
    look into the hole and see if theres a crack or something where the o-ring sits
    Midlothian, Texas
    Default Your radiator is dying. Replace it now and be happy in the long run.
    Mark Hall
    '95 525iA EAT chipped (just one now )
    '98 528iA
    Lincoln, NE
    Yup, sounds like the housing is cracking around the screw. You could try sealing it all up with permatex or other goop, but you'd be better off replacing the rad.
  1. Radiator screw plug leaking?
    By Yakker in forum 5 Series BMW
    Last Post: 01-11-2008, 09:02 PM
  2. Bleed screw
    By richie535 in forum 5 Series BMW
    Last Post: 11-05-2006, 11:41 AM
  3. m20 bleed screw
    By misfortune in forum 5 Series BMW
    Last Post: 12-01-2004, 02:27 PM
  4. Replies: 5
    Last Post: 07-31-2004, 11:28 AM
  5. Replies: 0
    Last Post: 07-31-2004, 10:45 AM
