Originally Posted by
bdonkersgoed
If anyone could answer the following questions as well, I would be most appreciative!
1.) How much should I expect to pay in repairs each year? This is very important . . . I don't want to get rid of one problem car to buy another . . .
2.) What are the most common problems with the car, and the estimated cost to fix? How much does a clutch replacement cost?
3.) What is the stock tire size? I have a fairly new set of pretty expensive Blizzaks that I am hoping will fit . . .
4.) What is the stereo setup in the car? Is the amp separate from the head unit? Is it difficult to install an aftermarket head unit? I just bought the new Alpine CDA-9835 (sweet deck!) and am hoping that it will work in the Beamer. If the speakers are only 2 ohms or something, it could cause problems . . .
5.) Do the 525i's come with remote keyless entry?
6.) I have heard that BMW parts are not as expensive as people think . . . I know OEM Lexus parts were expensive, so BMW is probably comparable?
7.) How does the RWD 525i handle in the snow? I live in Canada so it is kind of important . . .
8.) Is the car difficult to work on? Can only BMW technicians or specialists work on this car?
9.) You can see the rims in the picture above. Are these BMW rims? They don't look like the ones I see on other 5-Series BMWs . . .
10.) What type of light bulbs does this car take? I just bought Sylvania SilverStars for my Lexus and it would be perfect if they fit the BMW too!
11.) Is the 1995 525i what is called the E34 body style?
Thanks for your input guys! Hopefully I can get some responses before I go to look at the car If you wouldn't mind including the question numbers when responding , that would be very helpful! Thanks thanks thanks!!
Regards,
Bryan
