Results 1 to 5 of 5
Thread: Popping and Backfiring
    Aug 2004
    Default Popping and Backfiring
    I foolishly wash down my '92 525i engine three weeks ago, I clearly did not wet the computers. Now, about a week ago, my engine started to pop or backfire between 2000-3000 rpm, I assumed it was bad gas, so I add dry gas, injector cleaner, etc. now the start of the second week, same problem... a computer was hooked up to the engine,sparkpugs, coil, all components are working find, no sensor faults were found, after 3k rpm the engine runs fine...any suggestion on what to try ?
    Benneton (United Colors of)
    you might have water remaining in the spark plug wells, that's what mine did after i washed it and water got into the wells. it might have killed a coil by now, if it never dried out completely.
    Quote Originally Posted by pineman
    Aug 2004
    Default I check the plug again...
    Thanks...I don't know what else to try, we did check each plug, they were dry, I guess I will check in the wells...the problem of popping(backfiring) only occurs between 2-3 rpm, then it runs fines, Also, each coil was checked on the computer, they were fine.
    Fogtown
    Is it backfiring or missing?
    Aug 2004
    Backing , then it is missing between 2-3 rpm, then it runs fine...
    Quote Originally Posted by Anton CH.
  1. Since I've only been popping in here
    Last Post: 12-24-2008, 11:27 AM
  2. First gear popping out
    By paul_burkett in forum 5 Series BMW
    Last Post: 02-27-2008, 03:05 PM
  3. Just popping in to say hi!
    By Dan in NZ in forum 5 Series BMW
    Last Post: 06-17-2007, 07:10 AM
  4. found out why car was backfiring running rough
    By misfortune in forum 5 Series BMW
    Last Post: 05-17-2007, 06:15 AM
  5. weird fix for erratic idle, backfiring engine
    By dreamaker in forum 5 Series BMW
    Last Post: 10-06-2006, 06:52 PM
