Those three rubber strips are meant to seal the gap between the radiator and the support in front of the radiator. They are suppose to direct air through the radiator core and prevent bypassing the core. They are curved due to heat and age...they should be straight. The two short ones are for the sides, the longer one is for the top IIRC. It's been a couple of years since I had to deal with this. I left mine the side ones out without any consequence I can detect.
Paul Shovestul
Originally Posted by
Adnan
Hi,
I'm in the process of replacing the radiator on my '91 535i (manual) and found three rubber strips lying on the lower support. One is obvious because it was partially in place but the other two are confounding me.
These two are curved, almost like the fan shroud radius but I don't think they go there. Do they attach to the bottom of the radiator? They do have that typical slot that appears designed for slipping onto something.
Appreciate any assistance.
Adnan
