Hi all. Great forum here! 1989 535i owner for about 2 years.
I've got the usual dead power windows/locks/interior lights/wiper problem (all dead - all at once) that would usually be fixed with a replacement fusible link. My fuses are all good (ohm'd em out). My fusible link is under the back seat, and is not a bolt on like the one in the BMWE34.net webpages first picture, but like the last one. I cut the insulating heat shrink away and measured across the fuse, and it appeared to be good (0.5ohms). Also, it is crimped onto the wire connectors, and does not appear to be easily replaced.
My questions are:
1) How would you recommend that I replace the link (gonna try it for good measure and try to save some cash).
2) If the fusible link is good, then what?
Thanks in advance.
BMWCraig
