Results 1 to 4 of 4
Thread: running hot
    Homestead Florida
    Default running hot
    my 87 325is keeps running hot took out the thermastat since in miami but still heating up any suggestions
    baton rouge, loserana
    it must have a thermostat for the cooling system to work, without it theres nothing to slow the coolent down and let it absorb heat and or loose heat in the radiator, it's hard to say what is wrong with the cooling system, the thermostat may of died, the fan clutch is another suspect, the radiators on those early cars hardly ever clog up
    Quote Originally Posted by mrbmw1
    Aug 2004
    BILLINGS, MONTANA-LOT'S OF TWISTIES FOR THE WEEKENDS
    You'll Want The Lowest Degree Thermostat You Can Find, Use Heavier Oil,(20w-50?), Make Sure The Thermal Clutch For The Mechanical Fan Is Ok, Make Sure Aux. Fan Is Working, Or Hard Wire It To A Fuse/switch On The Instrument Panel And Run It All Of The Time. Good Luck!
    Homestead Florida
    I fixed it w/ new water pump & timing belt all else well I want to do the chsnge over to the 535 & 19# injectors I just asked another post for the info on how to do the conversion if you could drop me a line on the procedure at mrbmw1@hotmail.com
    thanks
    94 540i- 2.50 HP Racing exhaust, 2 3/4 lowered,18.8 HP Evo's,
    88 325ic- AC Schnitzer chip,3' lowered ,M3 body kit, 17.7 TSW Ribs
    Michael A. Johnson
    Mighty Mike's Sound & X-cessories
    MRBMW1
  1. It's just not running quite right...
    Last Post: 07-15-2008, 04:39 AM
  2. A Big 6 running on only 4?
    By Happy_Go_Lucky in forum 5 Series BMW
    Last Post: 07-18-2007, 11:28 AM
  3. Running hot!!
    By 535Bimmer92 in forum 5 Series BMW
    Last Post: 06-27-2007, 09:43 PM
  4. Please oh please, help me get my car running!
    By Antrieb in forum 5 Series BMW
    Last Post: 11-02-2006, 12:31 PM
  5. Bad running E34
    By Paul261267 in forum 5 Series BMW
    Last Post: 08-18-2004, 04:03 PM
