Results 1 to 7 of 7
Thread: Winfred, how about a limited slip for the 318iS?
    Dunlap Illinois
    Default Winfred, how about a limited slip for the 318iS?
    I've been toying around with the idea of placing a limited slip on the 318iS. The original gearing is 4.11 and is needed to help anemic starts. Finding a 4.11 LSD might be another story. Have you got any clues or suggestions or am I wasting my time?
    Jr
    Benneton (United Colors of)
    i dunno if it would even fit, but it seems as though almost all of the m50 automatic 525is have 4.10, and a lot of those are lsd....the 318 didn't have an lsd option?
    Default Limited slip on the 318iS
    My 318is has a limited slip, I can barely tell the difference. I've had the car since new and I don't think it has changed much over time. It is not much improved over my 73 2002tii with non-limited slip. I'm told that you cannot double the clutch plates to increase the locking, you probably could shim the existing plates but I haven't done that. I'm not sure where you get parts; I don't think BMWNA stocks diff. parts
    Any replacement diff. needs to come from a 318, the M3 and 6 cylinder cars have a larger diff and crossmenber. Not sure about E36 318 cars. The 318ic had a 4.26(?) ratio.
    Warren
    91 318is
    95 525iT
    baton rouge, loserana
    i need to dig around and see if i have a 4.10 ls, another choice if you wanna hold out for it would be a 4.27 ls, there rare as hens teeth but they are around. one thing you may need to do if you do find a ls diff you may need the 6 cylinder axles because the case on the ls is bigger and wider, i am not sure if they had a small case ls, i've never seen one in 8 + years of bimmer salvage, other diffs that will work with a cover/drive flange swap e28 and later e24/23 but most of those are lower gears and will kill off the line power, e30 325is auto's have 4.10 ls diffs i think the only cars that had the 4.27 were the 318 convertables and then as a option some had a 4.27ls. if i have a 4.10 ls i sell them for $400+ s/h i have trouble keeping them in stock so i may be out
    Quote Originally Posted by Jr ///M5
    Jr
    are you sure you have one, all of the 90/91 318is's ive seen have a regular unlimmited slip diff, i think that was the only e30 that the s option didn't meen you automaticly got one, my 3.73ls in my 325ism at 190k miles is as tight as it was at 120 when i got it and i flog the **** outta it, it breaks em both loose when pulling out quickly, my car would be undrivable without it at the power i am at now, it'd just sit and spin comming out of a driveway or any other weight transfering manuver
    Quote Originally Posted by WarrenBrown
    Winfred and Jr,
    4.10 diffs were used extensively on European spec models and are probably the best ratio for a four cylinder E30. Both the stock 318i and is models were imported with them. A number of track cars were converted to the 4.27 and all it does is turn the car into a four speed as first becomes useless. If you can get a 4.10 with LSD go for it. I still have bogging down on tight corners. Those with LSD just keep on going and seconds can be lost this way.
    Another approach was to get the dog leg Getrag 5 speed whose ratios are different with 5th being 1.00. Lets you squeeze every horse from the engine. That plus a codl air intake, exhaust and new chip will see the car putting out 150 HP and if you can source a set of Racing Dynamic cams then add another 10 horses to that.
    Can't wait to see what you do next.
    Good luck!
    Geoff
    '94 525iA
    the c 318 here has a close ratio 5 speed with a 1:1 5th (you should see what one does to a 325is talk about a useless 1st )
    Quote Originally Posted by Geoff Hoad
  1. 3.64 limited slip?
    By epj3 in forum 5 Series BMW
    Last Post: 05-09-2005, 09:00 AM
  2. Limited slip differential
    By drum2430 in forum 5 Series BMW
    Last Post: 03-05-2005, 03:00 AM
  3. Recommended oil for a 4.10 Limited slip differential?
    By atomicDog in forum 5 Series BMW
    Last Post: 01-01-2005, 02:44 PM
  4. Where to get Limited Slip Additive in Toronto
    By talltorontoguy in forum 5 Series BMW
    Last Post: 10-19-2004, 12:39 PM
