Results 1 to 3 of 3
Thread: Should fuel vapor valve draw a steady vacuum????
    Default Should fuel vapor valve draw a steady vacuum????
    I've still got a slight jerking feeling at either light throttle cruise conditioners, or when the throttle gets closed such as coasting down on the highway. Both of these are high manifold vacuum conditions. I've replaced a couple of original vacuum hoses that had cracks but still have this problem. The other day, I disconnected the fuel vapor vacuum line at the cannister located by the power steering reservoir (on my 1991 535i). With the engine running and warm, I did not have a steady vacuum from the open line, but a on/off type vacuum, say like a single cylinder engine might produce. I thought this odd but didn't know if that was something that the little inline electrically operated valve was supposed to do. Does anyone know if that's the effect a properly operating valve has?
    Grace and peace,
    Robert K
    1991 535i
    Default If it does it with the throttle closed I would check the tps setting to make sure
    that its going to the idle position... if this isn't working it will jerk some when coasting down... There's actually 3 settings on the tps for the m30... There's idle, and full throttle, then the other setting that the computer uses is the position that covers everything in between those 2... IF you suspect the tank ventilation valve is giving you problems then plug up the manifol hose and leave the tank unvented long enough to drive it and see if the problem is eliminated.
    Quote Originally Posted by Robert K
    Grace and peace,
    Robert K
    1991 535i
    Default As always Bill, thanks!
    I actually ordered a new throttle position switch and plug wires from BMA yesterday. As I had mentioned before, I know for a fact that the WOT switch in the TPS is not working now. I'll make certain the idle switch is being tripped when the throttle goes back to idle when I install the new one. The plug wires are 13 years old, so I ordered a new set of those too. One thing's for certain, once I get this problem tracked down, my car should be running perfectly! And...it won't leak on my nice, clean floor either.
    Grace and peace,
    Robert K
    1991 535i
  1. Where does the vacuum check valve go?
    By Brazilianbimmer in forum 5 Series BMW
    Last Post: 06-06-2009, 10:17 AM
  2. vacuum in the fuel tank
    By alex 1993 525i auto in forum 5 Series BMW
    Last Post: 08-31-2008, 07:20 PM
  3. Fuel & vacuum hose routing, m30
    By gale in forum 5 Series BMW
    Last Post: 10-07-2007, 10:38 AM
  4. vacuum leak at M50 valve cover- 12 inHg at intake
    By werminghausen in forum 5 Series BMW
    Last Post: 06-15-2007, 09:11 PM
  5. Valve Cover gasket == vacuum leak?
    Last Post: 03-10-2004, 12:32 PM
