Results 1 to 5 of 5
Thread: newbie
    kevind89e34 Guest
    Default newbie
    hey guys, new to the forum (have been watching it for a while though). i just purchased my first 89 e34 (79,000/auto). it needs the typical thrust arm etc replacement. besides that, this car is great. no explanation needed.
    i want to start doing my own work on this car, but i dont have a repair manual yet. can somebody tell me the torque specs for the valve cover and plugs?
    also, i have been reading about the "slush box" and how they are not that great. has anybody put a trans cooler on?
    thanks for the help and other info
    kevin
    NC
    Default Welcome Kevin! You've joined a great community!
    Quote Originally Posted by kevind89e34
    kevin
    You'll want to find a Bentley E34 manual to help you along. There's also a great reference site at Bruno's www.bmwe34.net. I don't recall the torque specs right off hand for the valve cover or plugs, but 10 ft. lbs rings a bell for the valve cover, and 18 for the plugs. Don't hold me to that-someone will chime in with the right specs for sure. And I believe most slushbox 525i's already have a tranny cooler (not entirely sure about your M20 version). On my '95 525ia M50, it's mounted in front of the radiator (somewhat attached). I have 119k on mine, but your mileage may vary. I have the fluid and filter changed every 30k (got one coming up at 120k).
    Again, welcome (and thanks for registering!)
    Bill B.
    Bill B.
    95 525i
    Default Hi kevin
    heres a link to all the books here
    and this one in particular is the one you NEED must have
    If you buy it (them?) through these links a portion of the price is donated to a very good cause.
    The slushbox doesnt need any additional coolers or modifications, just change the filter and the fluid that you lose during the change every 25 thousand miles.
    Boston & Attleboro MA
    Welcome... Ed.. Posts 1-25 s/b Newbie... 25-50.. Senior Newbie..
    baton rouge, loserana
    on the valve cover nuts just use a small wrench or 1/4 drive ratchet and use only wrist power, i just did a m42 318 motor build that i had to install 17 heli coils in the head because the former owner/mechanic didn't know when to quit. the package for the plugs should tell you torque, i feel them in, i've done so many i can snug them in till i have just squashed the crush washer (usually 1/2-3/4 turn past contact. the radiator has a trans cooler built in but you can bypass it if you want more, i installed a cooler from a e36 325 when i put a bigger 540 radiator in my 535 because the 540 radiator doesn't have a internal cooler, i just kept about a foot of the e36 metal lines and cut and flared them and double clamped them to the 535s rubber lines
  1. Newcomer - Newbie Section - Newbie Owner
    By rufryder in forum 5 Series BMW
    Last Post: 09-27-2006, 01:16 AM
  2. Hello from newbie
    By splower in forum 5 Series BMW
    Last Post: 11-18-2005, 06:08 PM
  3. Newbie with some newbie questions re: wheels, CD changer
    By hauler_525iT in forum 5 Series BMW
    Last Post: 10-18-2005, 10:49 PM
  4. newbie
    By tacm in forum 5 Series BMW
    Last Post: 11-13-2004, 04:57 PM
  5. NEWBIE here.
    By Sweetwater in forum 5 Series BMW
    Last Post: 06-10-2004, 09:30 PM
