Results 1 to 5 of 5
Thread: breather hose - a trick to installation?
    Default breather hose - a trick to installation?
    well the old breather hose (hose going from the throttle body to the valve cover) split and broke when taking it off the valve cover (when i first started the valve adjustment process)... took off the old breather hose but really had to man-handle the thing off the extremely-long connector... now i have a new hose, very flexible compared to the old one... but not flexible enough to get it on there without man-handling it again and i dont want to risk tearing another hose... would it even be worth it to take the throttle housing off the intake manifold (for easier installation)?
    lee Guest
    Default wd-40
    Maybe apply a little wd-40 to lube the hose before mounting. That should make it *easier* to slide on....
    well i got it on there eventually (using a screwdriver to really force it to wiggle on there)... now im stuck in a really dire situation...
    how in the world are you supposed to torque the 2 valve cover nuts that sit right under the intake manifold? not even a socket wrench will fit under there... much less a torque wrench...
    just use wrench and common sence, i hardly ever use a torque wrench on the non critical stuff
    snug her up and good to go! Just like a woman, dont need to torque her but you kinda know how much she can take.
    LOL
  1. Breather hose question
    By rockin1978TA in forum 5 Series BMW
    Last Post: 11-23-2009, 01:36 PM
  2. M52 rocker breather plate
    By billy in forum 5 Series BMW
    Last Post: 04-21-2009, 02:53 AM
  3. valve cover breather hose: hard?
    By schnell944 in forum 5 Series BMW
    Last Post: 12-09-2006, 12:09 AM
  4. fuel line breather hose why so long?
    By cschollum in forum 5 Series BMW
    Last Post: 01-11-2006, 07:41 PM
  5. fuel tank breather valve
    By albundy in forum 5 Series BMW
    Last Post: 04-25-2004, 10:28 PM
