Results 1 to 4 of 4
Thread: help! my fog lights keep falling out.
    SCHUYLKILL COUNTY, PA.
    Default help! my fog lights keep falling out.
    the plastic brackets are broke. do i have to replace the whole light unit? where is a good place to get the parts or does anybody have any used ones that are in good shape?
    thanks
    tim s.
    NY
    The new ones are ~80$ ea so I would try and get the brackets seperately. BMA would be my first try... other than that, maybe ebay has some used hella lights for cheap that you could salvage?
    Custom Turbocharged 1991 535iM - 135k mi.
    Meridian, ID
    I repaired mine. Seems that the usual thing that breaks off is the "ball" that goes into the socket. I dug around in my used bolts and screws bin and found a bolt that would go into the socket well. Rounded it off a little bit with a file and dremel and drilled a hole in the bracket. I think there was enough room on the back side to put a nut. I got it right and put some JB Weld around it to set it up well. I had originally tried to do this with the plastic ball but it broke off when I had to remove it and tried to reinstall. I'll do almost anything to save spending $80 bucks when I can rig something that works at home.
    Mike Holbrook
    Meridian, Idaho
    Default thanks
    i will need to remove the lights to see which parts are broke.
    tim s.
  1. Damn 5 is freaking falling apart....aaahhhhhh
    By mikell in forum 5 Series BMW
    Last Post: 12-22-2008, 04:13 PM
  2. Replies: 28
    Last Post: 06-04-2008, 03:42 AM
  3. Replies: 5
    Last Post: 07-16-2007, 01:01 AM
  4. Replies: 19
    Last Post: 06-28-2006, 09:39 PM
  5. The pieces are falling into place...
    Last Post: 05-29-2006, 10:07 PM
