Results 1 to 10 of 17
Thread: Waterpump pully tool?
    Default Waterpump pully tool?
    Does anyone have a blueprint of a waterpump pully too so that I can remove the clutch fan? Or a link to one...or something?
    TIA
    Benneton (United Colors of)
    which tool is it that you need pics/instr for? what is its purpose?
    to hold the pully from turning when I try to loosen the clutch fan
    Boston, Ma
    Im sure they have one at your local pep boys or autozone, they tool that is used on fords also fits on the e34, worked for me anyway
    Mar 2004
    We don't need no stinkin' special tools....Just place your thumb on the belt, to keep pulley from turning, while you whack the wrench with a dead blow hammer.
    Paul Shovestul
    TIA
    Default only if you could slip the fan and cluth through that little hole.
    Default too tight mann, I tried about everything to pop it loose
    even the hez looks like someone was in there and reefed the hell out of it to tighten it...probably has loctite on it with my luck.
    i didn't know what the heck you were talking about or asking about. autozone also has the extra thin 36 mm fan wrench for rent, too. you could rent two,. and stick one in the fan blades to keep the clutch from rotating
    Default Arghh
    nevermind, I'll mess it all up this weekend trying to get the pump off the thing with the fan on there I guess. Have to put some cardboard inbetween so I dont take out the radiator and Ill beat the mother on the bench. I also was checkin the new pump, I can stick a screwdriver in the impeller and lock the thing up but if its plastic I will have to take it out as a full assembly.
  1. Waterpump leaking..
    By Bo525i in forum 5 Series BMW
    Last Post: 01-06-2010, 12:43 PM
  2. laso m30 waterpump question
    Last Post: 05-16-2007, 08:07 AM
  3. Where do the waterpump fragments go?
    By scoop2004 in forum 5 Series BMW
    Last Post: 10-12-2006, 12:10 PM
  4. Waterpump questions
    Last Post: 04-21-2005, 12:48 PM
  5. How do you isolate which pully is making noise?
    By RobPatt 93 525ia in forum 5 Series BMW
    Last Post: 06-08-2004, 10:01 PM
