Just tested my resistor and it is bad. Can get the high speed to come on with the jumper, but not the low.
the problem with the cordoba resistor that i got is that it is 1.2 ohms. there is a 4 post resistor listed for the same car, i'm thinking that if i wire those resistances in series or such, might just make the perfect replacement. the wattage is more than adequate, 200 watts, price is definitely right, just need to test that 4 post unit.......i wonder if the one ohm unit will work OK if the 4 post doesn't pan out.
Originally Posted by Abnormal
