Results 1 to 10 of 11
Thread: Bad vibration from under car when accelerating
    Mar 2004
    Cambridgeshire, UK
    Default Bad vibration from under car when accelerating
    Let's be clear first off... this is not thrust arms.
    I had to load the car up pretty fully with band gear this weekend, and encountered a problem that hasn't gone away when unloading the car again. Could be co-incidence with the heavy load, or not. I dunno.
    Anyway, when I pull away or accelerate once on the move, I get a pretty bad vibration from under the car, sometimes accompanied by a knocking/ticking sound that rises with road speed, not revs. At constant speed it's absent, and it worst around the 50-60mph speed range.
    So I'm thinking it's something driveshaft related, which may have been exacerbated by the heavy load on the rear of the car. What are the possible causes do you all think? Is my wallet going to regret this? Can I trust a local mechanic to do the right thing with driveshaft stuff, or should I take it to a stealer?
    Thanks... (dreading the answers...)
    new540iowner Guest
    Default Check the center support bearing on the driveshaft...
    I had the same problem about a year ago. When I pulled the drivehaft, I found the center support bearing material was torn and allowing the driveshaft to hit the outer bearing support. What caused this though was the staked U-joint. The driveshaft shop that replaced the U-joint said there was a slight snag in the U-joint's range of motion. Cost was about $220 for them to disassemble, replace the center support bearing (part supplied by me for about $30), replace the staked U-joint with a circlip held U-joint, reassemble, balance and paint.
    Unregistered Guest
    Default My problem
    I had a harsh vibration turned out to be the waterpump starting to go and the rad fan was wobiling, its an outside chance but very easy to cheque, just see if there is any play on the fan and water pump area, mine could move in and out almost half an inch.
    Mar 2004
    A bad engine fan can cause ugly vibrations too, I replaced it with a BMW original and that concluded a 1 year's episode.
    Mar 2004
    Cambridgeshire, UK
    Thanks guys. Finally got to unload the car this morning, and the problem is now much less severe, though still present. That probably rules out water pump & fan, and the pump was replaced quite recently anyway.
    guibo?
    Mar 2004
    Cambridgeshire, UK
    Well I do wonder about the guibo too, given the pasting the autobox must have been giving it over the last year with my harsh 3rd into 4th shift issues. It'll be back to the shop this week, so we'll see what transpires.
    May some higher entity have mercy on my wallet.
    Mar 2004
    Cambridgeshire, UK
    Well, I guess I'm lucky on this one. Just had it looked at with a local specialist, and it's an obvious problem that I could have spotted myself: broken engine mount.
    Could have been worse...
    Atlanta
    Default Had that as well
    I noticed a little quicker though--when the blade came off it made a nasty dent in the hood
    Quote Originally Posted by tdgard
    that will explain why i have a dent on my hood from the inside and a new fan fitted!!!!!
    [IMG]C:\Documents and Settings\Fjord\Desktop\image094[/IMG]
  1. Jerking when accelerating from a stop
    By NielsGalan in forum 5 Series BMW
    Last Post: 03-13-2007, 06:53 PM
  2. slight surging while accelerating anyone?
    By csirisky in forum 5 Series BMW
    Last Post: 07-19-2006, 06:52 PM
  3. Strange noise while accelerating
    By Matias in forum 5 Series BMW
    Last Post: 07-28-2005, 08:44 AM
  4. Replies: 5
    Last Post: 05-04-2005, 11:59 AM
  5. E34 '91: vibration when accelerating
    By Tcdoe in forum 5 Series BMW
    Last Post: 03-23-2005, 08:53 PM
