Originally Posted by
Dan in NZ
Two weeks ago I got the "ENGINE OIL LOW", it had been 7000km since an oil change, so I topped it up and thought nothing of it. Today (2 weeks and 2000km later), I was surprised to get the message again, and saw that it needed another 3/4 of a liter. This engine normally goes 10,000km between changes without using a drop.
Also the engine temp has been up a bit, it used to sit dead-center and hardly move at all no matter what. Lately it's been about 1-2 needle widths hotter than the middle, and often climbs up to almost 3/4 going up hills, or slowing down after driving fast.
I did think I noticed a bearing sound at idle the other day, could it be a bad oil pump leaking and causing the engine to run hot???
I wouldn't be surprised if the thermostat was bad, in the last year I've replaced almost everything else attached to the cooling system including the water pump. Hopefully if the oil pump was bad it would fix everything!!!
