Hey guys, I need some advice. My car (89 535i)went into the dealership to get a new clutch. Found out that the flywheel is ruined. OEM flywheel is way to expensive.
I looked on Bavarian and they have the aluminum lightweight flywheel kit. What are the advantages and disadvantages of this. Does anyone have this setup in there car. Any other suggestions would be a great help.
There description:
520-170-240 Bavarian Autosport Aluminum Flywheel Kit $634.95
Our aluminum flywheel kit reduces engine rotational weight so your BMW can accelerate faster. The complete kit includes aircraft-quality aluminum flywheel, replaceable steel clutch disc surface, OEM dowel pins and pressure plate hardware, helicoil inserts, bolted-on starter ring gear, hardened flywheel bolt ring and flywheel bolts. It's a direct replacement for OE flywheels so no modification is necessary. 19 LBS LIGHTER THAN STOCK!
