Results 1 to 9 of 9
Thread: center tie rod HELP!!
    Dayton, Ohio
    Default center tie rod HELP!!
    Ok, so I'm trying to remove the center tie rod.... self locking nuts are off, but I can't get the center rod seperated from anything (idler arm, pitman arm, left and or right tie rod)
    On bruno's site there is this picture, anyone know where I can buy one of these?? And an idea of cost?? anyone want to rent me theirs
    Former: 95-530iM
    Current: 99 GMC Seirra 1500
    baton rouge, loserana
    wack the piece that the balljoint goes through while pulling/prying on the tierod, the shock usually loosens it and it drops out (if some ******* didn't godzilla the nut on)
    Dayton, Ohio
    I wacked just about everything on that center tie rod with no luck....
    I'm just going to have to get ahold of that puller thing
    Former: 95-530iM
    SCHUYLKILL COUNTY, PA.
    Default we used an air hammer tool.......
    my friend (& mech.) used his air hammer to drive out my center link when we replaced it. it was most definitly not coming out with just wacking at it a couple of times. i also did it in his garage with his lift.
    tim s.
    Dallas, TX
    I'm in the same boat. Fortunately, my indy is lending me the BMW tool (#322040) this coming week. I would think the puller you show would work, but am not positive.
    A few people make these tools, among them are: Hazet, Stahlwille, and Facom. Steve at The Ultimate Garage shows the Facom unit for about $65, which is far less than the Stahlwille tool, and the Hazet is more yet.
    I think the Facom tool number is U.16B. Give Steve a call and see if he can help you out.
    Robert Callaway
    Dallas, TX
    '94 530im 143k mi
    '94 Land Cruiser FZJ-80 202k mi.
    "If I could have back all the time and money I ever spent on cars.......I'd spend it all on cars."
    Tampa Bay, Florida, USA
    Default Pitman Arm-Center Link Removal
    OK, I've got the entire steerling linkage off EXCEPT for the Pitman Arm-Center Link. There is absolutely NO room to insert the tie rod remover between the Pitman Arm and the old center link.
    I may have to grind down the tie rod tool so it's thinner and can get in whatever gap there is, AND/OR I could get in there with a Dremel and cut a groove on each side of the old center link just to get enough room for the tool to slide in and proceed to pound it in with a big f****g hammer.
    Anyone done it this way? Is this PITA tight fit normal?
    Thanks to all who've posted tips esp BellicoseRightWinger for the JC Whitney tool link.
    Ramon/MBXB
    Quote Originally Posted by PhilipJCaputo
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Mar 2004
    I needed a puller, heat, and BFH. If you have and i6, you can use an iron pipe and hit down from above.
    Mike S.
    1992 535iM black/black
    1997 540iM white/gray
    Retired: 89 535iA, 85 318i
    <<Support your local autobahn, stay out of the left lane!>>
    Default Now thats really cheating!
    Quote Originally Posted by mikemaster
    Default Modified Tool
    Here's pics of the tool after modification. I ground the jaws with a shallower angle and made the tips come to a sharp point. This made it easier for it to get into the tight space and grab onto the tie rod.
    It worked great. You could easily center it on the tie rod.
    http://community.webshots.com/slides...214&key=fAaUPa
    Ramon
  1. Wheel center cap help ... please
    By GS535i in forum 5 Series BMW
    Last Post: 05-09-2008, 07:48 AM
  2. Which center cap should I use?
    By shanek in forum 5 Series BMW
    Last Post: 06-28-2006, 01:27 AM
  3. center tie rod
    Last Post: 01-06-2006, 03:19 PM
  4. Where to buy center tie rod??
    By PhilipJCaputo in forum 5 Series BMW
    Last Post: 06-22-2004, 03:01 PM
  5. center cap
    By robert g in forum 5 Series BMW
    Last Post: 02-17-2004, 04:49 PM
