Thread: compression check on m30
    Central NJ - USA
    Default compression check on m30 *update*
    i'm going to get it done this weekend.
    since we run 9.0:1 what should i be
    looking for? 160ish? i've got a 91 535i
    new head gasket, and 150ish thous miles
    Anything over 140 is considered acceptable. Look for an even spread with no more than 5 lbs variance across the holes. Make sure they do it warm and hold the throttle plate open.
    Bellevue WA
    86 Porsche 951 - Track Toy
    Lincoln, NE
    New HG? Was the head milled too? That might give you a little higher compression reading. I got around 170 on my 180k M30, with original HG AFAIK.
    The throttle body has a pretty handy little nipple that makes clamping the throttle plate open for the procedure very easy.
    I've also heard a 5% variance is acceptable, which would be more like 8-9 psi if you're reading in the 170 range. Just depends on who you ask, but they should be very close together.
    Central NJ - USA
    ok the guy didn't clamp the throttle plate open....i'll have to do it again
    1 - 150
    2 - 155
    3 - 155
    4 - 160
    5 - 155
    6 - 160
    oil pressure is 2 bar at idle and goes up to 6 with revs
    all the plugs are nice and clean (with EAT chip)
    Central NJ - USA
    do u think this kind of compression is ok?
    Default compression is perfect!
    Good to go, happy trails!
  1. Compression Check results, advice needed!
    By dwaynos in forum 5 Series BMW
    Last Post: 11-15-2009, 12:58 PM
  2. No compression - wtf?
    Last Post: 06-23-2007, 12:53 PM
  3. M50 low compression in cyl 5
    By wilkie3 in forum 5 Series BMW
    Last Post: 08-06-2006, 01:35 PM
  4. Low compression in 1cyl of M30...
    By Dan in NZ in forum 5 Series BMW
    Last Post: 12-20-2005, 01:36 AM
  5. How do i lower the compression on an M30 ?
    By 535ise in forum 5 Series BMW
    Last Post: 04-06-2004, 09:13 AM
