Thread: Engine oil press on 540i. Need advice please.
    Schuller Guest
    Default Engine oil press on 540i. Need advice please.
    ENGINE OIL PRESS message comes on after running for about 10 minutes then goes off after a few minutes but then comes on again. does this sound like a oil pressure switch or maybe the bolts on the pump are comeing loose. Anyone know what the symtoms of a oil pressure switch problem are or when the bolts on the pump are comeing loose? Thanks.
    Default Sounds like the oil pressure sensor is going bad
    The exact same thing happened on one of my 1991 525i's and replacing the oil pressure sensor solved the problem.
    Dick Schneiders
    Quote Originally Posted by Schuller
    This is definitely a symptom of loose oil pump bolts. Check it before it's too late.
    almost every v8 i've pulled the pan on has had loose (or fell out) pump bolts
    Winfred what do you do? clean em and use loctite?
    yep
  1. M30 ENGINE OIL PRESS issue resolved
    Last Post: 02-11-2009, 01:37 AM
  2. M30 ENGINE OIL PRESS issue resolved
    Last Post: 02-10-2009, 11:03 PM
  3. Engine Oil Press. Again.
    By White535Mtl in forum 5 Series BMW
    Last Post: 03-14-2007, 12:12 PM
  4. New to forum,advice on E34 540i
    By Fred/Houston in forum 5 Series BMW
    Last Post: 02-04-2007, 01:49 PM
  5. E34 540i V8 advice
    Last Post: 07-12-2004, 01:09 PM
