Results 1 to 5 of 5
Thread: 750 bushings?
    Mar 2004
    Pennsylvania
    Default 750 bushings?
    I am going to buy some 750 bushings this week from BMA. These are from an E32 7 series, correct?
    Mar 2004
    Pennsylvania
    Default Also. are thrust arms on an E32 and E34 the same?
    Quote Originally Posted by jjg43
    Mar 2004
    Pennsylvania
    Default Anyone?
    My thrust arm bushings are shot. I am wondering if I can just get the 750 bushings and knock them into my existing arms myself or if I have to buy the 750 arms with the bushings already in them? Are the E34 arms and the E32 arms the same part #s. BMA says they are not. Does this mean you can only use the 750 bushings but not the 750 arms? Thanks.
    Benneton (United Colors of)
    i dug through a bin of various bmw thrust arms (mostly e32s) looking for a e34, and i can assure you, the e32 dimensions are significantly longer than the 34 ones, they certainly won't fit. the e32 bushing will fit the e34 arm, however, with no modifications, so if the ball joint on the arm is acceptable to you, you can go ahead and put the e32 bushing in to the e34 arm.
    Lexington, KY
    yes, i believe you have to buy the lemforder arms with the 750 (yes e32 750) bushings already pressed in
  1. Thrust arm bushings
    Last Post: 05-08-2006, 05:15 AM
  2. What About These Bushings????
    By BMW4LIFE in forum 5 Series BMW
    Last Post: 11-10-2005, 02:27 AM
  3. Urethane E34 Bushings
    By Crewblunts in forum 5 Series BMW
    Last Post: 09-07-2004, 01:41 PM
  4. 750 bushings?
    By jjg43 in forum 5 Series BMW
    Last Post: 08-17-2004, 03:49 PM
  5. subframe bushings
    By robert g in forum 5 Series BMW
    Last Post: 07-29-2004, 12:19 PM
