Results 1 to 4 of 4
Thread: Sunroof seal, is it just glued on?
    Apex, NC
    Default Sunroof seal, is it just glued on?
    I'm redoing my headliner and stuff, while removing the sunroof panels (double sunroof), I noticed the seal around it was loose in the corners. Looks like it could use replacing. Looks like the same seal is on the back of the front sunroof panel.
    Is this just glued on? That's what it looks like to me. Anyone know what the deal is with this.
    Here's what I'm talking about (yeah, my clearcoat is scratched all to hell...)
    Scott
    '11 TSX Sport Wagon
    '00 328i
    '78 MGB
    '08 Saab Aero
    Gulf Coastal Mississippi
    the gasket is actually pressed on from the underside of the panel. The gasket has metal reinforcements in the rubber, which sort of clap to the edge of the panel, for lack of a more technical way to describe it. There may be a slight amount of glue in places. The last time I bought a sunroof gasket was for my 85 745i (greymarket), which has the same sunroof as the e23 7 series, and it was quite expensive, like $120. Hope it's not still like that. I need to order one for my 750 as we speak!
    1991 535i 176k (under serious surgery: repaint, interior swap, manual conversion, etc.)
    1993 750iL 132k
    Default Yes its glued on. The procedure is to remove the lid which you've
    already done ,then carefully remove the seal and all traces of the old adhesive then glue the new one on. As seen here
    Quote Originally Posted by JeremyT
    Apex, NC
    Thanks Bill, even tells me what adhesive to use!
    Scott
    '11 TSX Sport Wagon
    '00 328i
    '78 MGB
    '08 Saab Aero
  1. Some notes on replacing the sunroof seal
    Last Post: 12-02-2006, 01:41 AM
  2. Sunroof Seal Paranoia
    By SnakeyesTx in forum 5 Series BMW
    Last Post: 08-14-2006, 09:53 AM
  3. sunroof rubber seal question
    By kentish in forum 5 Series BMW
    Last Post: 09-15-2004, 12:58 PM
  4. To seal, or not to seal...
    By NoSpeedLimits in forum 5 Series BMW
    Last Post: 02-25-2004, 12:52 PM
