Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: Whats so special about BMW coolant??
    Default Where i live ambients of over 110 aren't uncommon and I've seen it at 124 before at
    bullhead city driving at highway speeds. I always use the stock bmw coolant since its not that pricey and i always use it at 50/50 concentration. Corrosion protection is my big concern and the raised boiling point. And Tiger motors will survice 275 just fine if they are using a synthetic oil that will continue lubricating just fine at higher temps. 250 temps are fairly normal on newer cars here and they run just fine at that temp. Straight water does have the greatest capacity for heat transfer but thats not an issue since the cooling system is already sized for a 50/50 glycol antifreeze and easily handles the heat load if everything else is in shape. And the typical racing motor actually has lower operating temps than the motor in a street car since the race car usually has a large oil cooler, radiator sized accordingly, a lower temp thermostat, no ac or few belt driven acc. to increase heat load on the cooling system and a richer fuel mixture since they don't have to run lean for emissions purposes. Street engine frequently work under harsher conditions including neglect..
    So i'd use bmw coolant 50/50 just like the engineers designed it for.
    Quote Originally Posted by George M
    agree with Paul...will take the corrosion protection of 50/50 to the added cooling benefit of 30/70 any day of the week...but I don't live near the equator either.
    George
    U mean the headgasket won't cook at sustained 275 degree whereas stock temperature is 190 degree?
    Unregistered Guest
    Also, BMW coolant might just be propaganda by BMW to buy their product. I seen many companies do this... Look at Microsoft. Really, what makes BMW's engine and cooling system any different than other German cars? Since BMW coolant doesn't cost that much, I still use it but are they puting one over on us? The properties of antifreeze/coolant is the same. What additives did they put in the coolant to protect it better than another quality brand? My friend's 1989 BMW used Prestone antifreeze/coolant since 1992 and never had a problem with cooling system. You be the judge...
    Quote Originally Posted by PhilipJCaputo
    Other than its blue, and normal stuff is usually green...
    I'm just about to replace the thermostat, thermostat housing (and thermo gasket)... and I'm not too thrilled with my bentley telling me that the entire system hold 12.5 liters of coolant! I'm going to have to go to the stealer and buy 3 jugs of bmw coolant at 15 bones a jug... which will double the cost of this fix.....
    any alternative to BMW coolant?
    How many "failures" has the BMW coolant had? I'd rather spend the extra few bucks for BMW coolant than take a chance on getting relabeled Dexcool.
    Unregistered Guest
    Hey, I don’t want to offend anyone who uses BMW coolant here. I too used BMW coolant for my 1995 BMW 525i. I’m just saying what PhilipJCaputo has brought up. What’s so special about the BMW coolant? I would like to know why, not because some company recommends it by gaining their own interest. Seriously, BMW is a business like any other. All companies claim their product to be the best. BMW isn’t in the business “solely” to make the “ultimate driving machine”. They are in the business to sell their product and make money. I like to know the facts… If all manufacture start to do this and we follow their guidelines without real facts, we would be the “suckers”.
    Quote Originally Posted by rickm
    Search the forum for coolant, that will keep you busy for a while One thread I read mentioned that the reason why (or one of the reasons why) is that the properties of the coolant factored in the makeup of the engines. I guess it's one of those "better safe than sorry" things...maybe Bill or Winfred could chime in.
    Unregistered Guest
    Default one view
    The way I look at it, these cars were $40-50K brand new. 12-15 years ago, I would have said you be nuts to not use BMW coolant, why risk it on an expensive car.
    However, your car, and I mean ALL OF YOU, are worth what - maybe $5K? 6K? If you really like the car and you some how "fry" your engine because you didn't use BMW coolant, its what $3K or so for a rebuilt!
    At this point, if you really don't want to spend the $18-24/gal (yikes, its really expensive in the SF Bay Area) to use BMW coolant, don't. What the hey, these old ass cars have seen their best days. Go on down to wal-mart, target, kragen/checkers or pep boy and get that "$2.99 special" and be done with it. Just remember to change every 2 years....
    Benneton (United Colors of)
    what is the difference between Green regular and German???? the most important reason is that green american coolants are BUFFERED as to make them phosphate free WRT pH. BMW and others actually ARE phosphate free, and contain the minimum silicates necessary that the water pump and other components are happy. water in an engine application undergoes changes in chemistry when exposed to the water jacket materials, rust, et cetera, heat. these coolants are made as to make these interactions as innocuous as possible when they inevitably happen...IE, a real world application would be water pump bearing death, or thermostat failure (or any other number of things that deal with chemistry) as a result of excess silicates (green stuff), or retarded rust buildup with time as a result of a more compatible chemistry of coolant. If myself, (or someone driving my car) avoids an unexpected coolant failure because the coolant is "workable" for another 20k miles or so, that's worth the extra $$$ to me, especially since most people today would drive a car with temps in the red to get to their destination.
    Quote Originally Posted by Unregistered
    Unregistered Guest
    O.K. I searched the forum for “coolant” and only found people having problems with cooling system. When BMW recommends only to use their coolant, is it from BMW bulletin, manual, or is it on the jug? Could someone tell me exactly what it said about BMW coolant (word for word if possible)? It’s hard to believe the BMW coolant contains special additive(s)… Or is it just been tested to be O.K. (compatible). If second, companies comment phrase in a way for the public to believe or perceive certain way without legal liability of false statement. Look at “NO PRESERVATIVE” compare to “NO PRESERVATIVE ADDED” on food product. One might think it contains no preservative to both but is it? “NO PRESERVATIVE” means no preservative. “NO PRESERVATIVE ADDED” means no preservative added by this company but might contain preservative. What's does it say? Thanks for putting up with my crap… You guys are a trooper!
    Dayton, Ohio
    Thanks for all the input.... I only drained about half the cooland out.... (only opened the plug on the radiator) So I was able to use the rest of my bmw coolant I had left over.... mix'n with a little distilled water, and its good as new!
    I just hope I never have to do that job again. Anyone try to replace the thermostat on the M60?? You can't even really see the bolts on the engine side of the thermo housing.. Plus there are other cords in the way... Plus with a cracked housing, EVERYTHING around there has this slippery layer of coolant all over it. Makes it hard to guide sockets into place
    And when they reccomend to remove the radiator fan... its probably a good idea, I fought with that thing the entire time I was change'n the thermostat & housing!
    good news is.... no more coolant leak! (that I've noticed)
    Former: 95-530iM
    Current: 99 GMC Seirra 1500
  1. some special stuff for the coolant freaks
    Last Post: 07-10-2008, 06:43 AM
  2. for that special someone
    Last Post: 10-12-2005, 08:12 PM
  3. whats this thing and whats the effect of a broken one??
    Last Post: 05-23-2004, 06:54 AM
  4. whats this thing and whats the effect of a broken one??
    Last Post: 05-23-2004, 02:26 AM
