Results 1 to 4 of 4
Thread: [E34] Central Lock programming
    Feb 2015
    Default [E34] Central Lock programming
    Guys,
    got 2 original keys with the car. Central lock never worked by remote. Key programming procedure pointing at the inside mirror no longer works.
    2 years ago, I tried programming both keys for central locking but everytime I succesfully programmed 1 key, the other key would stop working on remote lock.
    Now, the mirror procedure doesnt work at all. Keys are fine, batteries are fine.
    Do I need to reset something in the cars DWA to make the mirror procedure work again?
    Feb 2015
    First one with IR mirror. That initialization lock looks plausible. Time to get INPA/DIS out.
    Feb 2015
    Ok situation is about solved.|
    INPA was used to reset the initialization block. I was still not able to program my keys.
    I replaced my mirror with another mirror (IR receiver is in the mirror). I now have an auto-dimming mirror and can exclude my old IR receiver as troublemaker so its an upgrade at the same time.
    I waited a day before I tried to initialize again and I succesfully initialized 1 key. Since I did not have my spare key with me, I just have 1 key with remote for now.
    I will now arrange for 2 more keys from a junker, replace the cuts with an uncut bar and make 4 keys with remote cut to my locks. I will then (just in case) use INPA again to reset the initialization and will program all 4 of them one after the other.
    This should fix 4 keys (max is also 4)
    Possibly, the IR receiver went bad (POSSIBLY) since I was not able to initialize even 1 key after INPA reset. Changing the mirror solved that.
  1. central lock stucked at double-lock
    By nsbone_1988_520i in forum 7 Series BMW
    Last Post: 11-30-2006, 08:27 AM
  2. Central lock dilemma
    By aabdelhamid in forum 3 Series BMW
    Last Post: 10-30-2006, 09:19 AM
  3. Another pain in the a... Central lock problems
    By alikom in forum 5 Series BMW
    Last Post: 08-14-2006, 06:18 PM
  4. central lock problem! PLEASE HELP!
    By marko in forum 5 Series BMW
    Last Post: 07-11-2006, 11:29 AM
  5. HELP: central lock non-function and ABS on
    By nsbone_1988_520i in forum 5 Series BMW
    Last Post: 04-04-2005, 09:46 AM
