Originally Posted by
genphreak
Also considered the oxy sensor and the FPR? And btw 'non-gappable' are all gappable if you try. I usually compare the old to a new one out of the box before doing anything- they do wear and sometimes people fiddle with them without knowing what they're doing. I've seen some that have been dropped on one side- and it doesn't show unless you check them very carefully, esp if you wear glasses- though I wouldn't have said that before I had to get a pair for seeing things near me more clearly, LOL...
There is a solution somewhere. You must not expect obvious symptoms, codes thrown and so on for something that is causing power loss at high rpm.
There is a plain power loss across the board. Not only high rpm.
Recently I am getting a slight miss, when warm its ticking so low oil pressure is to blame. When cold we are also getting a miss. I only checked a couple plugs when I got it and the bolts for the coil packs were galled so I didn't check further since it was very smooth. Might JB weld all the galled ones and put ground straps but since I haven't had time to get into there it's all a guess now.
Hoping there is something stupid going on in there. Need to finish some loose ends as in the e46 i'm trying to turn plus other stuff and I'll chow down on this E34. Not sure of it's name yet as I might off it and get a fresh one... It just isn't personal to me like Nikki was.
