Results 1 to 10 of 10
Thread: Windshield Wipers
    San Diego, Ca.
    Default Windshield Wipers
    I hate to bother the bmw online community with this question but I can't find an answer.
    What size, brand ... windshield wipers work on a 1991 525i, I've gotten long ones that slap around and now I am completely unsure what wipers to buy. I like original equipment so any part numbers solving tech would be greatly appreciated. --- Dom
    San Diego, Ca.
    And size!!!!!
    01 WIPER ARM RIGHT 1 61611389052 $51.40 ENDED
    01 WIPER ARM RIGHT 1 61611384978
    01 WIPER ARM LEFT 1 09/1990 61618350715 $64.25 ENDED
    02 WIPER BLADE LEFT 1 09/1990 61618361475 $27.18
    ONLY APPLIES TO CO-DRIVERS SIDE
    02 WIPER BLADE 1 09/1990 12/1995 61618351760 $29.84
    02 WIPER BLADE 1 09/1990 12/1995 61618355052
    http://www.realoem.com/bmw/enUS/show...01#61611384978
    as for size someone with an E34 has to tell you
    I ordered 2 of these for $5.69 delivered, took almost 3 weeks. They are both 22" if I had to do it again I would go with 21" blades.
    http://www.ebay.com/itm/291549004405...%3AMEBIDX%3AIT
    Jan 2016
    Buenos Aires, Argentina
    im using 22" on both
    i believe you are supposed to use 24" on the passenger side, but i dont see the point. the 22" reaches everywhere you need.
    as for the driver side ... it has the inverted mounting hook, its a pain in the ass to get a compatible wiper. many people just swap the rubber on the original thing. i got a wiper from a brand called Trico, it does fit. But the spring doesnt put enough pressure so it leaves an annoying spot when coming down.
    E34 525i '88
    Quote Originally Posted by Coyote_ar View Post
    It does matter on the year in regards to the reverse "J" hook. I believe they all went standard after 1991 but not positive. With the generic wipers I bought I think it will work with both styles.
    Jan 2016
    is it possible to put a post 91 standard arm, on an older car?
    E34 525i '88
    Yes you need to use the whole arm from where the mounting bolt is. Everything will work the same except the hook is reversed.
    I retroverted on Nikka (94) for the aerodynamic M5 blade (Old style) It had some air scoop that held the wiper down in high speed applications. The old blade sucked so I got a new one and the aerodynamic scoop or whatever you call it was stupid. Wouldn't work in a carwash dryer, poor design. Complete waste of effort so I don't see upgrading to the new style being a bad move at all.
    Jan 2016
    yes, clearly the old thing depends on the aerodynamic scoop to work, cause when i removed the scoop thing to put my new trico blades. when im driving under 80kph, it works just fine. but when i speed up, i start having a spot on the middle where the return swipe wont clean the water. it seems the spring is not strong enough. the passenger side works just fine ...
    ill try to get one of those newer arms.
    E34 525i '88
    My new Hong Kong cheap blades also do the center miss action. It's nothing to complain about in regards to the price but I would sure make a fuss if I had to pay 10-15 each!
  1. Windshield Wipers?
    By Paul in NZ in forum 5 Series BMW
    Last Post: 05-03-2008, 07:01 PM
  2. chattering windshield wipers? How to fix
    Last Post: 02-27-2008, 09:11 AM
  3. Windshield wipers
    By aabdelhamid in forum 5 Series BMW
    Last Post: 11-14-2006, 05:04 PM
  4. Windshield wipers
    Last Post: 09-17-2005, 04:16 PM
  5. OT: e39 windshield wipers out.
    By tim in forum 5 Series BMW
    Last Post: 07-12-2005, 02:57 PM
