The actual park mechanism is robust and unlikely to have failed. Disconnect the shift cable at the tranny end and try to shift the lever on the side by hand. If you can move it, the cable is stuck. Happens some times if the car has been standing for a few weeks. If you can't, the manual shift valve may be stuck. Replacement costs about $15 and can be done without dropping the whole valve body.
