Results 1 to 10 of 41
Thread: Hello from Spain!
    May 2005
    central coast nsw au
    welcome Inmy, cant help u with the problem but nice looking car though
    Oct 2015
    Seville (Spain)
    Quote Originally Posted by mattyb View Post
    Many thanks matty!
    Oct 2015
    Seville (Spain)
    Many thanks, I have them all revised and new, all we have not seen is where it says' To the purge valve underneight the throttle ?? '' and the tube from the intake manifold ICV is not new
    Today I received the electrical system that goes up injectors and apparently everything is correct, the temperature sensor wires are frayed. I have taped well, I leave the video for ye see him better
    By the way I have just given me that I have two identical connectors. Agree that the canister valve. I have changed and then try them as the car goes, are both two pins, I have to check what color each wire carries. I only remember that one of them is yellow (you just put)
    Oct 2015
    Seville (Spain)
    the background sound is dual-mass flywheel shabby
    Oct 2015
    Seville (Spain)
    The idle is too low causing the slight miss/backfire. It almost sounds like an intake air leak somewhere. Have you cleaned the ICV and does it turn freely?
    I don't have a 3.5 so I can't tell you where the purge valve hose goes to.
    The video of the engine sounds like valves? Very hard to tell without hearing it in person.
    Are there any codes or engine lights light on the dashboard?
    I'm still thinking vacume leak.
    Oct 2015
    Seville (Spain)
    I cleaned the ICV and I think since doing worse, while it. A What do you mean with valves?
    This engine has very few empty sockets. And those are reviewed and this has everything perfect.
    Another thing that makes me, for example today, I notice that the engine speed does not accelerate, chokes, holds and paste explosions escape. It is unbearable. It also happens to me when I want to go from standstill creek but I play with the throttle. I will try a new ICV valve
    Not always does this to me, but the unstable idle if it is always cold
    Quote Originally Posted by Inmy7 View Post
    It runs fine when warm?
    Oct 2015
    Seville (Spain)
    The idle if it is much thinner. Today I passed a little throttle position switch and have the idle 1000 rpm. I do well, I think you have to have a distance from the throttle body butterfly 0.035. Correct me if it is not.
  1. Spain, Germany and the number 13
    Last Post: 06-30-2008, 03:17 AM
  2. E30 activities in Peņiscola, Spain
    Last Post: 02-06-2006, 04:49 PM
  3. someone from Spain needs E32 750 parts?
    Last Post: 11-24-2005, 12:52 PM
  4. Just got back from Spain... Auto Observations
    By DaCan23 in forum 5 Series BMW
    Last Post: 02-26-2004, 07:46 PM
