Page 2 of 2 FirstFirst 12
Results 11 to 20 of 41
Thread: Hello from Spain!
    Quote Originally Posted by Inmy7 View Post
    The idle if it is much thinner. Today I passed a little throttle position switch and have the idle 1000 rpm. I do well, I think you have to have a distance from the throttle body butterfly 0.035. Correct me if it is not.
    On my car the butterfly is almost completely closed, this is why we have the Idle Control Valve.
    By the way I have just given me that I have two identical connectors. Agree that the canister valve. I have changed and then try them as the car goes, are both two pins, I have to check what color each wire carries. I only remember that one of them is yellow (you just put)
    I have the V8 3.0 and there are also 2 identical electric connectors. It is possible these are switched?
    Also you might want to disconnect the battery for 15 minutes to re-set the engine computer after you change anything.
    I will try to monitor this thread more closely.
    Guess the timing chain was set properly, also the valves adjustment?
    Javier
    That was my first guess but then I thought they were hydraulic... That would explain everything.
    http://www.bmwe34.net/E34main/Mainte...lve_adjust.htm
    Oct 2015
    Seville (Spain)
    Quote Originally Posted by Javier View Post
    Javier
    I will review the distribution chain. The car starts perfectly relationship will not if. Adjusting valves did recently sounds great
    I thought that the lambda probe is not compatible. It is heated and when failure is more cold do not know if it will be related
    A small offset of the chain will not prevent the car from starting but may cause the engine be rough. Also over/under-tightening the valves will do a mess. I hear a significant ticking there, my computer even vibrates in sync.
    Oct 2015
    Seville (Spain)
    I will review this week without fail. I got a little tired and the problem of truth ....
    Thank you all, I will keep you informed
  1. Spain, Germany and the number 13
    Last Post: 06-30-2008, 03:17 AM
  2. E30 activities in Peņiscola, Spain
    Last Post: 02-06-2006, 04:49 PM
  3. someone from Spain needs E32 750 parts?
    Last Post: 11-24-2005, 12:52 PM
  4. Just got back from Spain... Auto Observations
    By DaCan23 in forum 5 Series BMW
    Last Post: 02-26-2004, 07:46 PM
