The idle is too low causing the slight miss/backfire. It almost sounds like an intake air leak somewhere. Have you cleaned the ICV and does it turn freely?
I don't have a 3.5 so I can't tell you where the purge valve hose goes to.
The video of the engine sounds like valves? Very hard to tell without hearing it in person.
Are there any codes or engine lights light on the dashboard?
I'm still thinking vacume leak.all we have not seen is where it says' To the purge valve underneight the throttle ?? '' and the tube from the intake manifold ICV is not new
I cleaned the ICV and I think since doing worse, while it. A What do you mean with valves?
This engine has very few empty sockets. And those are reviewed and this has everything perfect.
Another thing that makes me, for example today, I notice that the engine speed does not accelerate, chokes, holds and paste explosions escape. It is unbearable. It also happens to me when I want to go from standstill creek but I play with the throttle. I will try a new ICV valve
Not always does this to me, but the unstable idle if it is always cold
Guess the timing chain was set properly, also the valves adjustment?
Javier
That was my first guess but then I thought they were hydraulic... That would explain everything.
http://www.bmwe34.net/E34main/Mainte...lve_adjust.htm
A small offset of the chain will not prevent the car from starting but may cause the engine be rough. Also over/under-tightening the valves will do a mess. I hear a significant ticking there, my computer even vibrates in sync.
