Results 1 to 3 of 3
Thread: How do I use '89 E34 535i diagnosis port?
    May 2015
    Default How do I use '89 E34 535i diagnosis port?
    Hello dear BimmerNuts,
    does anybody know how to read engine codes, or perform engine diagnosis via the diagnosis port of the E34 535i? I am hoping to be able to extract the LongTermFuelTrim or similar parameters.
    Thanks alot
    Jazz
    A normal tool will not work, that is pre-OBDII system. Some people use the interface from Gert rv8flyboy, see here http://www.interfaces4beemers.net/
    The 1989 M1.3 Motronic is stone age of diagnostic, the number of fault codes you can retrieve is very limited. Same as my 1.2 Bosch end number -156 for the M70 engine.
    In case you have a U.S. spec car, then you can make a stomp test to get the fault codes, details on my website below.
    The Peake tool will give you basically the same as the stomp test.
    May 2015
    Alright, thanks for the help !
  1. What is this vacuum port to?
    By 94e34m60 in forum 5 Series BMW
    Last Post: 08-17-2012, 10:36 AM
  2. What does this port on M50 oil housing do?
    Last Post: 09-06-2008, 06:24 PM
  3. Port & polish -- the right way (?)
    By gale in forum 5 Series BMW
    Last Post: 11-21-2007, 10:08 AM
  4. '97 528i, No Signal at OBD-2 Port...
    By ///M-Power 3\\\ in forum 5 Series BMW
    Last Post: 12-16-2006, 10:45 PM
  5. Replies: 8
    Last Post: 12-10-2005, 01:56 PM
