Previous owner used a diesel 40body...
Easiest to install is the same engine, no changes necessary, just think about ECU, engine wiring loom, transmission, driveshaft length/size, cooling system etc.
Oh, try a search, you'll find more than enough opinion on the subject.
*RIP Oskar the DOG*
Mobil1 0-40 in the USA
Uhm, Shogun, he's looking for oil, not an engine
I have the same M50 non-vanos and have been using a full-synthetic Mobil1 0-40 or similar weight synthetic castrol for many years. vehicle is only driven in summer months, oil get changed once per year.
Dave
*RIP Oskar the DOG*
Sorry, I thought he wants to change the engine, misunderstanding, should have read more carefully.
Is the Mobil 10 _40 good for the tropics..
I'm in Trinidad. .....Yeah jack warner......
Currently use a 10w40 high milage oil and change once a year in my 95 with M50 engine. Only drive it about 1300 miles a year.
Yes, no problem, I live in Japan and in summer season with hot climate it is between 25 up to 35 degree Celsius and my E36 M3 uses Mobil 10W 40. Mobil I use because I can get it cheap here from Costco, actually I have no preference. Regular change and a filter change are more important.
