Disassemble the heater valves and clean them. Relatively easy. On my website http://twrite.org/shogunnew/topmenu.html click on the left fixes>>>see under climate control , plenty of pics how to do
Shogun's right.
Of course...
The way it works on an e34 is:
Hot coolant from the engine is drawn by the electric coolant pump (in the heater valve assy) into the heater valves. If the thermostatic cabin controls direct these to open, hot coolant will flow to the right and left side of the HVAC/IHKA unit in the dash and heat the cabin. Yu need to 'hose in' to the pump, and hose out from the heater core return pipe/s.
Once the heater valve assy is disconnected you can flush by disconnecting the input hose for the left and right core feeds in turn and connecting your garden hose. Then point the output hose (you might need to attach a short piece of hose to directs the waste water down away from you).
That's about it, but whilst you are at it you should flush the block and the radiator and replace the coolant with the correct stuff to see you through the next couple of years. I usually flush my system with water by draining once a day for a few days, replacing with local (thankfully soft) water. Do not do this in a hard water area. Because I drain it fully each time a number of times the car ends up just running water. I do this to be sure I get all the coolant out and avoid removing the block drain which is hard to get to at the back under the exhaust manifold. By contrast, the radiator drain can is a neat little blue plastic plug that I can operate by hand. After flushing every few days (with heater controls fully on and bleeding to remove the air), I drain again once more and add enough coolant to get a 33% mix.
In your position though you must drain from the block primarily (so jack the car up and support it high enough for you to be comfortable working behind the manifold) as you will remove more gunk that way- the radiator drain doesn't allow anything large through it, and a lot of the gunk will be hanging around in the block
BTW: An M50 takes 10.5 litres/11.1 quarts, and M30 roughly a litre/quart more.
Hey Shogun - Saw your pages and am encouraged to undertake the valve cleaning project. I would imagine if the valves are gunked-up (recall I poured head gasket sealant into my engine, which has caused my nightmare), so must be the heater core. If I'm cleaning the heater valves manually, wouldn't their removal present an opportunity to back flush the core? Any link to someone's experience doing so would be very helpful. Thank you!
There are only 2 hoses going to the heater core, the others just control the direction of flow through the heater core.
