Results 1 to 10 of 10
Thread: Fuel economy on manual m50 and manual m30.
    Jul 2004
    Default Fuel economy on manual m50 and manual m30.
    I am looking to possibly swap to m50 manual from m30 automatic, or perhaps just go with a manual swap into the existing m30, and would like to look into the figures for education.
    Please post fuel economy figures of what you encountered in your cars - manual m50, manual m30.
    deleted air conditioning
    M50 stick = ~7.5L/100km highway, ~9.0L/100km mixed.
    Dave
    Jul 2004
    Quote Originally Posted by Dave M View Post
    Dave
    Thank you, Dave.
    Jul 2004
    Dave, what engine rebuild have you done, and did it affect the fuel consumption figure?
    Sep 2007
    Michigan
    M30 with 5 speed and 3.91 rear gears 22mpg on the highway and ~18 around town.
    Low compression in cyl. #5. Used block, honed, new rings, main and rod bearings. Te head was cleaned up as well. It ran quite well before the work, but burned some oil. Mileage did not improve significantly following the work.
    Dave
    Jul 2004
    Thank you, Dave.
    Jul 2004
    Interesting Ahlem, and thank you for the post. My understanding per realoem was that 3.45 rear was fitting for m30 with 5 speed... Curious what numbers that setup returns.
    I have both. Definitely the M50 is better on fuel by perhaps 20-30% in real terms. Easiest way would be a whole engine bay content swap- but in real terms, an M52 3.0L would be the best choice- you could handle the OBD1 wiring work without much trouble and it'll run better and return better fuel economy than any e34 ever did. With the 6 spd manual I imagine you'd want a 2.93:1 rear end so something from an e32 would do well, so long as it is LSD equipped :-)
    Jul 2004
    Thank you, genphreak.
  1. 525i manual fuel consumption??
    By BMWDriver in forum 5 Series BMW
    Last Post: 04-04-2008, 03:20 PM
  2. Replies: 2
    Last Post: 04-23-2007, 09:29 AM
  3. M5 Owner's Manual / Bentley Manual
    By e34it in forum 5 Series BMW
    Last Post: 09-12-2006, 01:11 AM
  4. 535i AT in Manual Mode vs. Economy Mode
    By xtmsports in forum 5 Series BMW
    Last Post: 03-22-2005, 07:23 PM
  5. 535 Economy/Manual mode slider
    By cappy in forum 5 Series BMW
    Last Post: 04-21-2004, 05:44 PM
