E34 Power steering leak fixed!
Well I finally pulled the engine and replaced the steering box. The V8 makes things horrifically difficult, you cant even see the box from the top side.
Not!
I changed the old looking reddish gray fluid with CHF 202 a while back and had to refill it every 4 days or so. Getting down to the bottom of the can so I ordered 2 more cans that arrived yesterday. Then it dawns on me, when was the last time I had to fill it up? Look under the car and it is dry.
So that's the fix, order way too much fluid and the leak will stop.
I'm not sure if I should flush it again or just leave things be. Fluid isn't bad looking or anything just a bit discolored...
Think I'll just forget about it for a while.
