it won't hurt the running being bad but if it works it may help power
1990 325is. During trouble shooting the bad idle, discovered that the full throttle switch has a resistance of 25 to 100 Ohms when closed. It should be close to zero Ohms (The idle switch is close to zero.). 100 Ohms is surely a lot less than infinity (open switch), but I don't know if it is low enough for the DME to reliably interpret it and provide the appropriate mixture enrichment. I can't notice any obvious problems under full throttle operation. It seems fast and smooth, with no stumbling upon acceleration.
Should I change this switch?
Reomve off the cover and clean the contacts w/ 320 grit emery cloth.
Paul Shovestul
Originally Posted by Warren N.CA
with sandpaper and the like. This will cause pitting, arcing, and failure within a short time. If I go to the trouble to take it apart, I will put in a new switch.
Originally Posted by Bellicose Right Winger
Never? Nonsense. As someone who has done this successfully on numerous occasions, I completely disagree. Furthermore, since it's likely your contacts HAVE already failed, you can't possibly make them any worse. Emery cloth and sand paper are completely different animals.
Paul Shovestul
it's usually just oil that's screwing with them on the tps wot switch
of mist from the crankcase and gets sucked into the manifold will settle out some and it ends up in the tps gumming up the works... frequently if you take it apart and clean it up with some contact cleaner it will work fine.. And since its a low amperage contact point they usually aren't burnt... And all electrical contact point manufacturers state not to file or sand their contact points for the reasons that Warren stated.. On large amp carrying contactors its the kiss of death but you can usually get away with it on something like these switches that don't carry any current.. and if i was in a bind i would file or sand them anyway just to get me out of the bind...such as a 115F day and my home ac compressor has kicked out on overload cause one set of contacts have arced out and its trying to run on one phase of power.... That said i wouldn't hesitate to clean them up with some emery cloth if the overall condition of the switch looked pretty good.
Originally Posted by winfred
...and not fubaring the switch. When I opened up my old TPS for this picture, I don't think it would have been possible to put humpty-dumpty back together again. I recall the cover came off in several piece's even though I was trying to be careful as I pryed it apart.
Bellevue WA
86 Porsche 951 - Track Toy
Originally Posted by Bill R.
Originally Posted by Jeff N.
