I can give you the data from the German E34 forum
Technische Daten V8-Motor M60
Model..................l 530i............................ 540i
Kennzeichnung...... M60B30.................... M60B40
Ventile/Zylinder........... 4........................... 4
Nockenwellenantrieb..Steuerkette......... Steuerkette
Kraftstoffart............. Super.................... Super
Bohrung [mm].......... 84............................ 89
Hub [mm]............... 67,6.......................... 80
Hubraum [ccm]......... 2997....................... 3982
Verdichtung [x:1].........10,5.......................10,0
Leistung [kW/PS].......... 160/218............. 210/286
bei Drehzahl [1/min]......... 5800................. 5800
Drehmoment [Nm]............. 290.................. 400
bei Drehzahl [1/min]...........4500................ 4500
Kompressionsdruck [bar].... 12-14.............. 12-14
You can see the difference in HP 218<>286 and the torque 290<>400.
Then the 530 has a 5HP18 ZF auto trans and the 540 a 5HP30.
530i M60B30 8-Zylinder, v-max 235 km/h, 0-100kmh 7.7 sec.
540i M60B48 8-Zilinder , v-mx 240 kmh (with limiter), 0-100 kmh 6.8 seconds.
final drive
530, manual gear 3.07, automatic 3.15, Touring 3.23
540 2.93
