Results 1 to 3 of 3
Thread: 530 v 540
    May 2005
    central coast nsw au
    Default 530 v 540
    I have seen a very vey nice 530 for sale at a very good price albeit 4000kms away. I have only ever had 540i ( twice and spoilt ) and I am curious as to the difference between the two, apart from the obvious displacement 3lt v4lt, what are others thoughts/experiences on the 530?
    regards Mattyb
    I can give you the data from the German E34 forum
    Technische Daten V8-Motor M60
    Model..................l 530i............................ 540i
    Kennzeichnung...... M60B30.................... M60B40
    Ventile/Zylinder........... 4........................... 4
    Nockenwellenantrieb..Steuerkette......... Steuerkette
    Kraftstoffart............. Super.................... Super
    Bohrung [mm].......... 84............................ 89
    Hub [mm]............... 67,6.......................... 80
    Hubraum [ccm]......... 2997....................... 3982
    Verdichtung [x:1].........10,5.......................10,0
    Leistung [kW/PS].......... 160/218............. 210/286
    bei Drehzahl [1/min]......... 5800................. 5800
    Drehmoment [Nm]............. 290.................. 400
    bei Drehzahl [1/min]...........4500................ 4500
    Kompressionsdruck [bar].... 12-14.............. 12-14
    You can see the difference in HP 218<>286 and the torque 290<>400.
    Then the 530 has a 5HP18 ZF auto trans and the 540 a 5HP30.
    530i M60B30 8-Zylinder, v-max 235 km/h, 0-100kmh 7.7 sec.
    540i M60B48 8-Zilinder , v-mx 240 kmh (with limiter), 0-100 kmh 6.8 seconds.
    final drive
    530, manual gear 3.07, automatic 3.15, Touring 3.23
    540 2.93
    540s seem to have lots of power at lower rpm's than the 530. You can put a lower gear ratio in there to compensate. I did this and it made a big difference in city driving. Highway mileage stayed about the same even at the higher rpm's. I put (I believe) a 3:64 LSD in there which I think was a bit high, a 3:43 would be about perfect.
