Originally Posted by
genphreak
That looks excellent! What is the steering wheel kit worth?
I buy mine from the distributor in Pymble, he's closer.
Here's a tip- if your wheel is loose at the top (when holding it you can twist the leather and padding underneath back and forth- (easy to feel as at the side near the spokes it is nearly always solid), the glue sticking the foam padding to the steel ring in the middle will have given way. To fix, just use a hypodermic syringe to inject some glue inside. I think contact glue is ideal, but super glue apparently works without the hypodermic if you drill a few small holes around the inside where the padding has become loose- just large enough to accept the nozzle. Don't squeeze too hard! and be ready to wipe the excess off (prtect your eyes too, jic!)
