Originally Posted by
Jachenbach
Hello again,
1992 525i wagon experienced trans prog and limped home yesterday. Will check fluid level today but question is do I have a transmission control module (AGS or EGS)? Bentley manual does not show until 1993. Is there a relay I should check as well. Thanks Jim
Yes, you have a TCM and it stores a fault code if you get transprog. Have the fault code(s) read and that will point you in the right direction. It could be something as simple as a low battery. But to save time and money swapping bits, I'd suggest you check the codes. It is why they are there and what the dealer would do
