Results 11 to 20 of 22
Thread: Low power at low rpm (below 2200 rpm or so)
    Quote Originally Posted by alex 1993 525i auto View Post
    If the cam are advanced at default position (or low rpm), but my Vanos 'stucks' the cam at the 'retard' position, could then be explaining the car's low power at low rpm?
    Yes exactly.
    Apr 2007
    I checked again TPS and it's resistance is in the specs.
    I cleaned the ICV toroughly drawing it in isopropanol for an hour and cleaning it with cotton swabs. It was not so dirty but after the valve was moving freely if shaking the valve. Also its resistance was as per Bentley.
    I checked fuel pressure (and pressure regulator) and it's fine. (52 psi) One thing I noticed is that the system doesn't hold pressure as long as it should (loss of 12 psi in 20 min instead of 7 psi) but I don't think it is related. When engine is running, if I depress the throttle the pressure increase then goes back to normal.
    I still have to remove the valve cover gasket to see under if something looks weird.
    I wonder if the MAF is not monitoring the air flow as it should. I changed the air filter (was not that dirty but was 1.5 year old) when I replaced the camshaft position sensor and it didn’t change anything. The car idles fine, but if I depress the throttle it is like if it was missing air in the mixture (or fuel but pressure is fine, injectors look clean). I can hear a sound like ‘baahh’ when I depress the throttle, and if I depress it fully the engine dies. In Bentley I can only find resistance specs for AFM before 09/92’s E34, for M50TU the only test given is voltage on the harness… which is fine on my car.
    Any help in testing MAF (BMW part no. 13621747155, Bosch 0280217502)? I checked like on the net and can't find much on that...
    Alex
    1993 (build 93/05) 525i automatic M50TU (vanos) 263K miles (ca. 423000 km) in Montreal, Canada (bought the car 9 years ago in San Diego, CA)
    So are we going to finally check the VANOS? Video it or take pictures for the archive.
    You already did the MAF check... what's holding you back now?
    Apr 2007
    Hi there,
    You guys were right about timing/VANOS:
    The nuts holding the stop plate and diaphragm spring went loose and the spring disk was destroyed, the sprocket on the intake cam was loose on the cam and the chain chewed the tensioner (pic attached, also you can see the 2mm stop disk was being machined by the cam… as well as sprocket) Attachment 8019Attachment 8020 This was causing power surge in RPM below 2000 and no-start below 0 oC/32F.
    I finished putting together the engine after replacing the upper timing chain, sprockets, spring plate kit, rail guide and tensioner. I did the job exactly as described in the Bentley with all the tools etc. (even tightening the primary chain tensioner to 11 in/lb of torque in the timing setting sequence, as told in the Bentley for M50). I was very cautious as to putting the VANOS back in properly, with the piston fully pushed-in, and with the chain and secondary sprockets turned fully clockwise before inserting with the first matching tooth of the gear and so on.
    The car started fine but the idle is now uneven and sometime the engine stalls after starting or when stopping at a red light, or after I give it a burst of gas let’s say from the throttle body (idle was fine before this repair). One good thing is the the power loss below 2000 RPM is now gone; when I take-off it doesn’t surge, it accelerates like before the problem appeared. Still no codes of course…
    Upon searching like what is wrong, I found a comment on Pelican website write-up on VANOS installation, dated September 16, 2013: <There's also a BMW tech bulletin on the non-M3 motors that dealt with advancing the timing. So, sometimes if you replace a gasket and don't advance the timing back to where it was, then that might make a difference. That's about the extent of what I know on that issue. The advancing wasn't for more power, it was to eliminate a shaky idle…>
    Can anyone find more info on this advance timing BMW tech bulleting? I can’t find anything on the TIS, neither Googling it… Do you think it can be related to my rough idle symptom? Any other ideas what to check beside this? Do you know if I can test my VANOS system without the special tool that I can’t find anywhere? (12 6 410 to simulate the solenoid function)
    I drove it for 60 miles or so to see if the problem would vanish but no, still there. I guess I’ll have to remove the cover and check my work… Video attached of the behavior of the engine when idling and running (sound is bad but it can give an idea).
    Thanks for any hints!
    Alex
    Apr 2007
    pics for previous post were not attached properly, here they are:
    Name:  tensioner and disk.jpg
Size:  90.4 KBName:  sprocket.jpg
    Alex
    Timing can definitely alter the idle. I have no idea about the bulletin though. You did reset the computer?
    Apr 2007
    Yes I did (1st I unplugged the battery when I saw this uneven idling,then I tried the Shogun's reset procedure, both didn't change it).
    Sorry, I do not know that engine, actually have never worked on a M50TU.
    What however I would check once more is, that the engines does not get false air, brittle vacuum hoses - even if they look still o.k. from outside - can cause idle problems.
    I had a similar problem on my E36 M3 from 1998 with an S52B32US engine. Got a strange noise when starting mainly cold engine for some time. Checked the internet and all showed in direction of a Vanos problem = ticking noise for short time when the engine is started cold.
    Never had to install the ordered Vanos repair kit. The problem was a brittle vacuum hose from the air pump to the check valve on the exhaust.
    I found this info:
    Tech Note The following BMW factory bulletin could have been placed in the TSB section of our catalog, but I thought it would better serve in the TechNote area so I might be able to explain why this pertains to catalytic converter codes and failures.
    Although this bulletin is pointing toward BMW secondary air injection fault codes, there is some very important information embedded in here. See Item 8 on Page 3 of the body of the bulletin.
    They are making mention of the possibility of cracked vacuum lines going to the non-return valve. They’ve even updated the vacuum line since 11/98! This can be an underlying cause of a lean condition, but worse yet, if a cracked vacuum line is affecting only one or two cylinders (closest to where the vacuum source is), this could result in un-equal fuel distribution. If one or two cylinders is running lean for any reason, there will be left over oxygen after combustion. The upstream O2 sensor will see this oxygen and report to the Powertrain Control Module that a lean condition exists.
    This will prompt the computer to increase the injector on time or pulse width across the board because it has no idea that just one or two cylinders are running lean. This condition causes the other cylinders to run RICH! YES, a single lean cylinder or two can cause the overall system to run rich which is a MAJOR contributing factor to carbon and soot buildup. Also, conditions like this can contribute to substrate melt-down due to excessive fuel in the exhaust! See the bulletin below:
    SI B 12 04 00 Engine Electrical Systems November 2002 Service Engineering This Service Information bulletin supersedes S.I. 12 04 00 dated July 2000.
    [NEW] designates changes to this revision
    SUBJECT Secondary Air System Faults
    MODEL [NEW] All models with M52, M54, S52 and S54 engine All models with M44 engine produced as of 1/97 [NEW] All models with M60 (3.0 liter) engine produced as of 10/94, M62 engine produced as of 9/98 [NEW] All models with S62 engine [NEW] All models with M73 engine
    SITUATION
    Customer complains that the "Check Engine" lamp is illuminated and the following fault is set in the Engine control module (ECM/DME):
    [NEW] M52, M54, S52, and S54 engine:
    Fault code 245 (F5 hex) – Secondary air injection, bank 1
    Fault code 246 (F6 hex) – Secondary air injection, bank 2
    [NEW] M60, M62 and S62 engine
    Fault code 80 – Secondary air injection, bank 1
    Fault code 81 – Secondary air injection, bank 2
    M44 and M73 engine:
    Fault code 80 - Secondary air injection system
    CAUSE
    Failure within the secondary air injection system.
    PROCEDURE
    The following diagnostic tips / steps should be followed if the above customer complaint is received:
    1. For E36 vehicles equipped with M52 engine prod. 10/95 - 2/96 also refer to SI 12 04 96 regarding Recall Campaign No. 96E-A01.
    2. Refer to the OBD II training manual for illustrations and explanation of system operation.
    3. Perform test modules/component activation of secondary air system located in the "Service Functions" section using DISplus/GT1.
    4. Check operation of secondary air pump using instructions provided in DISplus/GT1.
    5. If pump is not operating correctly check air pump relay. For vehicles with M52 engine a modified relay was introduced into production P/N 12 63 1 742 690.
    6. If the relay is operating correctly and the electrical connections/wiring to the pump are OK, check the condition of the pump.
    7. If the air pump is seized it must be replaced.
    Important note: If the pump is seized as a result of moisture (water in pump), an improperly operating non-return valve is the cause. The non-return valve may stick open and allow exhaust gases to condense within the air pump housing leading to a failure of the pump.
    Non-return valve sealing / leakage check:
    The non-return valve must be checked as follows any time a seized secondary air pump has been replaced due to moisture. Disconnect the air pump feed line/hose (1) at the non-return valve (line from the secondary air pump to the non-return valve).Visually inspect the non-return valve fitting internally for carbon type contamination. (Twisting the corner of a clean shop rag into the valve fitting as shown will assist with this check.) If no carbon type deposits are found on the rag, this indicates that the non-return valve is sealing correctly and does not need to be replaced. If carbon type deposits are found on the rag, the non-return valve is not sealing correctly and must be replaced. Note: A non-return valve which is not sealing correctly will cause damage to the secondary air pump as described above.
    8. Check also for cracked vacuum lines going to the non-return valve.
    For vehicles with M44 engine the vacuum line P/N 11 73 7 501 180 going to the non-return valve has been improved since 11/98.
    For E46 323i/iA and 328i/iA vehicles produced 4/98 - 7/98 see S.I. number 12 04 98 regarding the vacuum hose to the secondary air non return valve service action.
    A Non-return valve with a dated code stamping as of 99T075 (arrow) and later is the improved version. date cose explanation: 99=year, T=day, 075=75th day of the year.
    Only the improved non-return valves are available from the Parts Distribution Centers.
    I found that on Diversified Environmental catalysts technotes.deccats.com/BMW_Vacuum.pdf‎
    Apr 2007
    Thanks a lot for the info, the M50TU doesn't have the secondary air pump as far as I know, so it may not apply for my car. Anyone ever seen where I could buy the special tool 12 6 410 to simulate the solenoid function by any chance?
    Alex
  10. #20
    Apr 2007
    Ok I got it working fine now!
    I did a silly mistake when putting back my solenoid piston, I put it the other way arround... damn I felt bad for 4 days thinking what the hell did I do wrong when putting back the Vanos and redoing the timing... at least I didn't have to open it the cover to find nothing was wrong in there.
    This part:11361738495
    http://www.realoem.com/bmw/showparts...g=15&lang=enUS
    The car runs super well now.
    Alex
  1. Puddle + power steering = No Power steering
    By ahlem in forum 5 Series BMW
    Last Post: 04-20-2013, 08:18 AM
  2. Arrgh! Radio power = 0, Amp power = 0
    Last Post: 09-11-2007, 12:23 AM
  3. No Power
    By Visions in forum 5 Series BMW
    Last Post: 10-28-2006, 09:10 PM
  4. Replies: 2
    Last Post: 12-01-2004, 02:58 PM
  5. Replies: 8
    Last Post: 07-12-2004, 11:53 AM
