Results 1 to 4 of 4
Thread: Interior light does not stay on for a few seconds after I close a door
    Lexington, Kentucky
    Default Interior light does not stay on for a few seconds after I close a door
    Interior light used to stay on for a few seconds after I close a door. Does not anymore. What to check?
    That is controlled by the GM. Maybe you once reset the GM and test.
    All general modules must be plugged in only after disconnecting the vehicle's battery. If the vehicle's battery is connected when the GM is installed, undefined signal contacts can cause an incorrect vehicle configuration to be stored, resulting in the impairment of one or more of the above-mentioned systems. If one or more of the GM functions are impaired in this matter, the GM can be "cleared" by disconnecting the vehicle's battery for at least ten seconds.
    The switch-off delay of the interior lights which occurs after entering the vehicle and closing the driver's door has been reduced from 20 seconds to 15 seconds on the newer GM from 09/1991.
    Lexington, Kentucky
    Thanks, My battery ran down as I think interior light (switch in wrong position) was on all evening. had to jump start the car. Perhaps tha caused me to notice the prolem. I think I will diconnect the battery tommorrow and see if that resets the interior lights.
    Keep us posted!
  1. Oil light takes a couple of seconds to go out from cold
    By sidevalve in forum 7 Series BMW
    Last Post: 06-05-2008, 05:52 PM
  2. Interior light door switch
    By Bimmer93 in forum 5 Series BMW
    Last Post: 05-20-2006, 06:24 AM
  3. door won't stay open...anyone had this problem???
    By Robert K in forum 5 Series BMW
    Last Post: 10-29-2005, 05:53 PM
  4. Door brake/stay confusion??
    By pundit in forum 5 Series BMW
    Last Post: 02-12-2005, 06:08 PM
  5. interior & trunk light don't turn on with door
    By RIPN RAY in forum 5 Series BMW
    Last Post: 01-14-2005, 04:47 PM
