Originally Posted by
Warren N.CA
Removed, inspected, cleaned ICV. It seems to move freely and looks good. It buzzes and vibtates satisfyingly when the ignition is on. Resistance across its terminals exactly as specified by Bentley. The voltage at the Harness connector seems OK, although one of the outer terminals measures only 5 Volts, as compared with 10 Volts on the other. I have discounted this difference as insignificant, am I wrong about this?
The throttle idle switch operates perfectly, and its applied voltage is as specified. (The full throttle switch operates, but has a resistance of around 100 Ohms, in the closed position, cometimes dropping as low as 25. This is not good, but I'm not having problems that I know of at full throttle.)
Next I plan to test the coolant temperature sensor for correct resistance. (Don't know how I'll get the connector off with the fuel rail in the way.)
Also, Im going to try to determine if it is running rich or lean by observing the behavior per Bentley.
Funny, just after starting, it idles fine for several seconds, then suddenly the idle speed drops way down and it tries to die, unless I catch it with the throttle.
Car is '90 325is
Any insights?
