Results 1 to 10 of 12
Thread: 1997 528 sputters on start up
    Nov 2005
    Ann Arbor, MI
    In a different direction, my car was doing something similar to yours and it turned out to be a failing MAF. Rough idle when starting up in the morning/after work. Lots of hesitation/low power/threatening to stall until the engine warmed up. I replaced the MAF yesterday and it now drives like a champ. It's an expensive sensor but if you've ruled everything else out, you might consider it. Or at least consider taking the MAF out and cleaning it with some MAF cleaner from your local auto store. I have a different motor than you (M60b30) but I would imagine MAF symptoms are the same across motors.
    1994 530i - 117,000 miles
    @milue:
    Just beware, different MAFs or perhaps just changing them can change the feed signal that the ECU has learned to live with. I recently changed one on my M50 (when it is probably my o2 sensor causing all the running at normal operating temperature troubles) and it ran great.
    Then after a tank of fuel or so the troubles returned.
    There are many sensors, in my experience one really needs to replace the O2 sensor and engine temp sensor every 100,000km and check things like MAFs if they are known. Else you have to remove and test them when you get running problems...
  1. 1997 528I - How are they?
    By vping in forum 5 Series BMW
    Last Post: 02-08-2012, 08:44 AM
  2. Ot: 1997 Mb E420
    By jjg43 in forum 5 Series BMW
    Last Post: 10-06-2006, 10:58 AM
  3. 1997 Bmw M3 4dr Auto
    By OPENROADOFEDISON in forum 3 Series BMW
    Last Post: 05-01-2005, 07:05 PM
  4. 90 525i Sputters When Cold
    By Pwr2spare in forum 5 Series BMW
    Last Post: 11-12-2004, 09:48 AM
  5. OT - 1997 VW Cabrio
    By Scott E in forum 5 Series BMW
    Last Post: 04-14-2004, 09:43 PM
